Post by 808ministroke on Oct 28, 2019 16:05:49 GMT -5
I don’t think it’s a blocked jet as I tried two different carburetor s . Checked for spark again with a new plug and spark was real strong I guess my next step will have to be renting a compression tester from auto zone.. how would I know if a soft seizure acurred ? What would be the damages caused by that?
Post by geoffh on Oct 30, 2019 15:34:23 GMT -5
You can,t "think" it,s not a blocked jet or other problem you will have to check.Are you fully assembling the the engine before trying to start it,pay attention to the air box,chin up keep checking.
Post by 808ministroke on Nov 13, 2019 1:19:31 GMT -5
Well I shattered my wrist..... skateboarding..... not even going that fast what a shame. Well I came to the conclusion that the engine needs to be torn down and replace wring gaskets n such n check for anything problematic. But I can’t do shit with one hand surgery is scheduled for Friday the 15 th so hopefully in like six months ha... ☹️
Post by aeroxbud on Nov 13, 2019 16:08:55 GMT -5
That's not good. Heal up quick buddy.
Post by 808ministroke on Dec 16, 2019 4:32:27 GMT -5
Hey everyone my arm is close to healed so back to the no start issue, I bought a compression tester for 15 bucks !!! And it seems like my theory of worn ring possible gasket but if that was the problem then I would see a water leak or water leaking into combustion chamber making a lot of smoke I would think 🤔. So compression on the cold engine was 90psi . That’s low I know but what psi am I shooting for with this engine? Overse.? Going to tear it apart soon anyway but I wanna know what compression I am shooting for.thx🔨🔜🧨
Post by 808ministroke on Dec 18, 2019 6:02:45 GMT -5
So no one can tell me what acceptable compression is💬❓I went back and watched some of Brent’s old instructional videos . So I know that for troubled starting 100 is minimum. I ordered a new ring and gasket set for my bore going to be interesting as I never assembled the bore and don’t know what the inner workings and how the case was cut to accept it....
Post by 90GTVert on Dec 19, 2019 13:27:51 GMT -5
I don't know exactly what cranking compression you are looking for with this engine setup, but I would expect 150psi anyway. Definitely not 90. Other possibility would be a compression tester not sealing, which is usually involving where it screws into the spark plug threads.
Post by 808ministroke on Dec 22, 2019 18:01:16 GMT -5
Okay so I got my parts in literally two days all the way from Canada to Hawaii.
Post by 808ministroke on Dec 22, 2019 18:03:21 GMT -5
Post by aeroxbud on Dec 22, 2019 18:07:41 GMT -5
That's the biz! 👍
Post by 808ministroke on Dec 23, 2019 3:00:57 GMT -5
I got it all reassembled with new gaskets and ring .sorry it was to hard to get a good shot of the case wrk... was so clean and beautiful I wanna cry 😭..... h and I finally found out what kind f crank is in this beast ....drumroll please.... Hebo don’t know what model but it would bet their best one. I thought hebo was Europe only.
Post by extreme on Dec 25, 2019 19:00:52 GMT -5
Not sure if u r still in need , but I have malossi inner rotor,stage six overange and a malossi as well as malossi, MHR pipe, lots of other goodies as well
Post by 808ministroke on Dec 27, 2019 23:12:27 GMT -5
.yah I still need a inner rotor and maybe upgrade my transmission is that your stuff I seen on offer up?
Post by 808ministroke on Dec 27, 2019 23:26:21 GMT -5
So I can’t get it to start only kick start a close look and I saw what could be a slight gap at the back of the cylinder I kinda figured I would have to open the lid and retourqe the cylinder bolts......also I got a very interesting radiator it has two layers and only one inlet and one outlet could be very mice because of that although could a expansion tank still be used and how?
Post by 808ministroke on Dec 27, 2019 23:54:01 GMT -5
