Post by niz76 on Jan 4, 2022 17:12:25 GMT -5
Sounds like Street Wolf is an ambitious project. Keep us updated!
Post by Scootrific on Jan 4, 2022 19:58:17 GMT -5
Sounds like Street Wolf is an ambitious project. Keep us updated! Yeah, it is.
Post by Scootrific on Jan 5, 2022 10:44:46 GMT -5
Yesterday, I screwd up my 2nd fuel tank, that I had for the Baotian project. I tried to weld an hose nipple under the tank. It did not go so well, so I did cut off the hole thing and tried to weld it to another tank, that I had. I did screw up that thank too, because the fuel tank metal is so thin, that I burned through the tank, after that it was leaking few places near the weld. So I had a idea to weld an peace of metal, to strengthen the welded area. That attempt made the tank situation even worse, the tank was still leaking.
I have a 3rd fuel tank too in the garage, but it is suitable for the BT50QT-9 model. In my country, there is lack of parts for those Chinese scooters like BT49qt-20 and BT50QT-9. If Im lucky, then I might find something in Germany (Scooter-Attack) etc. Option 2 is find another donor scoot.
I was thinking and one thought came into mind - I might make a template, draw it to metal, cut the peaces and weld it together, like I made the Battery box. I have a second battery box too, but I used a template to make it. That one is still not welded up.
But, there is some good news too, what makes me smile. I made contact to the MotoGadget crew and they apologized for the waiting time. I ordered those things (10th november 2021): 4x mo.blaze LED turn signals, M-Button and mo.relay+ for the 4 turn signals. The reason for the delay was, that people were sick. Yesterday I got a email, with the bill, that they send out, when the order is shipped.
The screw up video:
Post by Scootrific on Jan 5, 2022 10:59:14 GMT -5
So far I have spent over 700€ on my project (MotoGadget stuff). The scoot did cost about 270€, the donor scoots were 300€. Next things on the list for my project, will be: 1. TrailTech Vapor Kit, Generic Inverted Forks, 19mm Water Sensor (# 752-119) (The water sensor I will use for the oil temp) or Striker Kit, Generic Inverted Forks, 19mm Water Sensor (# 712-119) 2. Vapor Indicator Lights, Dashboard, fits Striker (# 022-PDA) or Indicator Light Dashboard, Universal, fits Trail Tech Digtal Gauges (# 022-IDB) 3. Surface TTO, Temperature, Black, Radiator Hose, 19mm (# 742-EH1)
4. Sensor, Temperature, Cable Extension, 48in (# V300-48) x2 5. Surface TTO, Tach Hour, Black (# 742-A00)
Post by Scootrific on Jan 6, 2022 21:38:12 GMT -5
Post by Scootrific on Jan 7, 2022 5:26:36 GMT -5
I had a nice surprise today. I went to get new work clothes and when I came back to home, there was a missed call and message from FedEx guy on my phone. I called him back and he said his: "Are you home right now? I will be there in 30 seconds!" I said to him, ok, I wait outside then. The stuff from Germany (Motogadget) arrived to me. 1. 4x Mo.blaze LED turn signals. 2. M-Button. 3. Mo.relay+ for the turn signals.
Post by Scootrific on Jan 7, 2022 11:35:21 GMT -5
Post by Scootrific on Jan 8, 2022 3:31:02 GMT -5
Post by Scootrific on Jan 10, 2022 7:09:41 GMT -5
Today I finished my night shift at 8am. After that I went and brought a scissor jack, went to garage and made a lift. Also, I placed second coat of fiberglass to the bottom of fuel tank. For safety, I added the stand, what came with the project scoot to the rear. I need to make a new one or modify that one. Next time, I hope to start wiring the scoot and Motogadget M-Unit maybe.
Post by Scootrific on Jan 11, 2022 12:43:17 GMT -5
Post by Scootrific on Jan 11, 2022 14:28:28 GMT -5
Here is the video, what I did today (new battery box and under seat area for battery + other electrics etc.
Post by Scootrific on Jan 12, 2022 13:09:04 GMT -5
Post by Scootrific on Jan 13, 2022 9:33:16 GMT -5
Post by Scootrific on Jan 14, 2022 8:55:52 GMT -5
Last time, I finished the metal work of the under seat electronics apartment. I also made a braket for the ignition key, but right now, Im thinking, where to put it. Here is a Part 7 of the Project Street-Wolf:
Post by Scootrific on Jan 18, 2022 12:59:27 GMT -5
Because, working in my garage with only +2 degrees celsius, I took M-Unit and the wiring kit home, where is +17 degrees celsius. Big 15 degree difference while working. I do not want to get cold. I made this at home. Now it is little bit simpler, to connect and add wiring to the scoot:
