Post by aeroxbud on May 19, 2023 4:43:01 GMT -5
Radiator placement is always a tricky job. Most scooters are quite narrow at the front.
Post by Scootrific on May 23, 2023 19:19:06 GMT -5
Radiator placement is always a tricky job. Most scooters are quite narrow at the front. Yeah, That front is quite narrow, because it was air cooled scooter. But I will think of something. 1. Maybe under the battery tray or front of it. 2. under the seat 3. front of the scoot, by modifying the nose mount little bit.
Post by aeroxbud on May 24, 2023 0:51:31 GMT -5
My Yamaha jog RR had the radiator under the floor boards. Quite a clever solution. But it's quite a bit smaller than an Aerox radiator. If you got some MX radiators it allows a bit more freedom has they are twin style rads.
Post by Scootrific on May 25, 2023 12:17:51 GMT -5
Post by aeroxbud on May 25, 2023 14:51:54 GMT -5
Have you got the rear disc brake caliper and line already?
Post by Scootrific on May 27, 2023 6:04:19 GMT -5
Have you got the rear disc brake caliper and line already? No, I do not have the rear disc brake caliper, but the line I did order from Germany. Im gonna replace both lines front and back.
Post by Scootrific on May 27, 2023 6:04:35 GMT -5
Yesterday, I placed Order to Scooter-Attack. All parts will go on the Baotian build. Total including shiping from Garmany to my countri in EU was about 500€:
2 × Exhaust Gaskets w. screws 50cc scooter - 14,80 € 1 × Exhaust Header Pipe derestricted, Aprilia SR (Piaggio) - 33,50 € 1 × Reed Valve Malossi MHR VL11 Piaggio NRG / Typhoon- 54,00 € 1 × Stage6 Fuel Gauge MK2 black - 75,00 € 1 × Rear Wheel Nut with cap and cotter pin Piaggio M16 - 4,30 € 2 × Repair Kit / Fasteners fairing parts (x18) - 6,60 € 1 × Brake Hose rear Stage6 200cm, 90 + 45 - 72,00 € 1 × Brake Hose front Stage6 110cm, 90° + 25° - 59,00 € 4 × Cable / Hose Clamp rubber-lined d=16mm - 19,60 € 1 × Subframe Axle Stage6 Piaggio / Gilera titanium - 89,00 € 6 × Spacer Polini for radiator mount plastic MBK 51 / Peugeot 103 - 31,80 € 1 × Shock Absorber Forsa Aprilia Sport City One 50 4T / SR Motard / Derbi Variant Sport - 39,00 €
Post by Scootrific on May 27, 2023 9:23:15 GMT -5
I just now did think about one other thing, that the new/old Piaggio engine does not have .... I need to find a original Air filter box too to that engine. Also I have to make a side stand too. I think I have a second scooter frame somewhere. I hope that had the side stand mount. I know, That I have 1 or 2 side stands.
