Post by Scootrific on Jan 19, 2022 11:10:03 GMT -5
Today, before coming to my day-job place, I vent to garage and did some fast work, by welding a Starter solenoid place to the under-seat area. Also, made wires for it. 1. The red beafy wire with 40A fuse from battery + side to the solenoid 2. From solenoid to starter. 3. Second beafy red wire from starter solenoid to the M-Unit Blue + terminal. I continue the wiring work next time, I hope. One dude will come and look at my Baotian BT49QT-9D, what is sor sale right now. I hope he will buy that, so I can put the mone to this project. Some solenoid wiring pics:
Post by Scootrific on Jan 19, 2022 22:27:56 GMT -5
I was thinking about wiring little bit and connecting lights, buttons etc. I´m planing to use Deutsch dt 2-pin, 4-pin and 6-pin connectors. I believe, that going this way is safer, then using the original connectors. Indicators = 4x 2-pin Rear light/ brake light = 1x 4-pin Front Low/High beam = 1x 4-pin Front position light = 1x 2-pin Starter solenoid (start-button) = 1x 2-pin Regulator/Rectifier = 1x 4-pin MAgneto/Stator = 1x 4-pin Lock/kill (with key) = 1x 4-pin Oilpump = 1x 2-pin Temp sensor (oil) = 1x 2-pin Temp sensor (head) = 1x 2-pin Munit inputs and outputs = 4x 6-pin Total 16 Deutsch dt connectors (5x 4-pin, 9x 2-pin and 4x 6-pin). (Might add more)
Post by Scootrific on Jan 20, 2022 13:10:04 GMT -5
I think, I will add a number to my project name too. "Street-Wolf 4-2-1"
"4-2-1" means: 4-Stroke, 2-wheels, 1 cylinder
Post by Scootrific on Jan 22, 2022 13:06:58 GMT -5
Post by Scootrific on Jan 24, 2022 14:08:56 GMT -5
Today I brought 2 rolls of wire (black and Red) and some wire connecting rods (picture 1). Made 2 DIY distribution blocks for Power and ground wires for the scoot. I did not have my soldering station at work, wo I will fine tune this distribution block thing in the garage, by soldering all the ends and connecting all the wires with solder. Also I will heatshrink the blocks after soldering. But for now the distribution blocks look like this (picture 2). Pic 1 Pic 2
Post by Scootrific on Feb 1, 2022 1:35:07 GMT -5
I took few days break from garage, because the trail to the garage, from my work place was so wet and icey and also down hill. I decided to not work on my project, but yesterday I went and did some soldering and labeled all the M-Unit wires.
Post by Scootrific on Feb 15, 2022 18:05:28 GMT -5
Post by Scootrific on Mar 6, 2023 13:20:01 GMT -5
Post by Scootrific on Mar 7, 2023 12:10:13 GMT -5
I was thinking, and maybe it is cheaper to convert the 90cc 4T engine back to 50cc (temporary), to get it legal. Then I do not have to buy an new engine. And after passing the legal stuff and getting the documents, then converting it back to 4T 90cc.
Post by Scootrific on Apr 29, 2023 15:40:45 GMT -5
Post by Scootrific on Apr 29, 2023 15:42:03 GMT -5
For the speedo, I will use Trail tech Vapor maybe
Post by Scootrific on May 3, 2023 10:39:24 GMT -5
Post by Scootrific on May 3, 2023 22:49:02 GMT -5
Post by Scootrific on May 5, 2023 9:35:52 GMT -5
Post by Scootrific on May 17, 2023 6:34:50 GMT -5
Today came in a package from Germany (Trailtech) for my project.
