Post by dankhill on Mar 18, 2020 14:53:59 GMT -5
Looking at the wheel mounted...I don't think I need to shift the engine mount.
FYI - I am using a Ruck swingarm and a stock wheel/tire size combo (for a Ruck).
When I get time in the next few days I'll have to address the top mount location of my shock to get the clearance needed. I'll update as I get into it.
Post by Happypancake! on Mar 18, 2020 15:30:35 GMT -5
I looked. I don’t have an extra stock shock laying around
Post by dankhill on Mar 18, 2020 16:52:13 GMT -5
Thanks. I appreciate you looking.
I am thinking of finding a cheeapo shock online to GET rolling for now.
Post by dankhill on Mar 22, 2020 9:53:47 GMT -5
Post by dankhill on Mar 22, 2020 9:55:45 GMT -5
Any jet recommendations to GET me started?
Post by Happypancake! on Mar 22, 2020 10:56:29 GMT -5
Any jet recommendations to GET me started? 38 SJ 80/82MJ no larger. Can u spin the bottom of that shock 180deg?
Post by dankhill on Mar 24, 2020 19:21:14 GMT -5
So....I checked and rechecked the valve shims... is this noise bad Haha? What could it be?
Post by Happypancake! on Mar 25, 2020 10:22:15 GMT -5
So....I checked and rechecked the valve shims... is this noise bad Haha? What could it be? I’d check again. IN @ 0.10 mm. Ex @ 0.19. If its hard to start when warm it’s the exhaust valve. You have oil in right??? Half way full is the correct amount . My 4-valve GET taps. I’ll try to video the 58cc later today
Post by Happypancake! on Mar 25, 2020 10:43:32 GMT -5
Cold engine. No tap.
Post by dankhill on Mar 25, 2020 14:35:45 GMT -5
Yes I have oil in... so half of the 600ml that's in the manual? 300ml total oil?
Post by dankhill on Mar 25, 2020 14:39:31 GMT -5
I'll recheck the shims. To me it sounds like the wrong shims too
Post by Happypancake! on Mar 25, 2020 16:06:57 GMT -5
Yes I have oil in... so half of the 600ml that's in the manual? 300ml total oil? Whatever half the dipstick is
Post by dankhill on Mar 25, 2020 16:58:57 GMT -5
Yes I have oil in... so half of the 600ml that's in the manual? 300ml total oil? Whatever half the dipstick is Would over full oil put additional pressure on the valves?
Post by Happypancake! on Mar 25, 2020 17:27:59 GMT -5
Whatever half the dipstick is Would over full oil put additional pressure on the valves? Nah. Low/no level would make it tick
Post by dankhill on Mar 25, 2020 20:58:58 GMT -5
So I shimmed and re-shimmed. I think I have the right ones in (.1mm in and .19mm out) with no improvement.
I played around with the belt to feel the engine turn and I think I found a hitch in ther exhaust valve. I compared it to a stock GET and there's def some fuckery there.
I got new valves and didn't adjust anything in the valvetrain. Could that be the issue? Do I need to tear back down and lap the exhaust valve?
