Post by Happypancake! on Mar 26, 2020 5:21:35 GMT -5
Don’t tear down yet. Pull off the variator and start up. Tick still there?
That hitch is may just be the flywheel magnets.
Post by dankhill on Mar 26, 2020 14:04:11 GMT -5
I'll try to get a video tonight of me working the piston by hand so you cab hear what I found...
Post by dankhill on Mar 26, 2020 14:06:00 GMT -5
Don’t tear down yet. Pull off the variator and start up. Tick still there? That hitch is may just be the flywheel magnets. I did that and the sound was still there. should I pull the radiator to check the flywheel magnet?
Post by dankhill on Mar 29, 2020 9:11:18 GMT -5
Here's the noise with the variator pulled. Im going to heat up the garage for a bit... then I'll get a video of the noise when I turn the engine by hand.
Post by Happypancake! on Mar 29, 2020 9:44:47 GMT -5
Might be a bad crank bearing. not good.
Post by dankhill on Mar 29, 2020 12:05:21 GMT -5
Exhaust valve
Intake valve
Post by dankhill on Mar 29, 2020 12:08:33 GMT -5
Might be a bad crank bearing. not good. I was thinking I may have installed the old bad crankshaft assembly... but I checked and the bad one is still on the work bench with the old parts. Could a new bearing be junk out of the box?
Post by Happypancake! on Mar 29, 2020 13:04:36 GMT -5
Are you at TDC when that valve opens ? almost sounds like its hitting the piston
Post by dankhill on Mar 29, 2020 15:06:25 GMT -5
Are you at TDC when that valve opens ? almost sounds like its hitting the piston Yeah I am pretty sure it is TDC. It clicks as the line on the chain sprocket crosses the index mark.
Post by dankhill on Mar 29, 2020 16:36:08 GMT -5
View from spark plug
Post by Happypancake! on Mar 29, 2020 18:52:33 GMT -5
your timing is 180deg off
Post by dankhill on Apr 4, 2020 13:59:10 GMT -5
So I tore down the top and repositioned the cam...I think.
The cam lobes were pointing towards cylinder side. T mark on the flywheel was aligned as well as the stopper plate and sprocket markings.
I have no idea what I'm doing wrong here...
Post by dankhill on Apr 4, 2020 14:02:55 GMT -5
Post by krisgenchev on Apr 5, 2020 1:32:44 GMT -5
It doesn't sound like main bearings, it sounds like rod bearing since when they spin out , the rod starts having movement up and down and it make this noise. Drain your oil if there is glitter in its bearings 100 percent
Post by krisgenchev on Apr 5, 2020 1:37:17 GMT -5
your timing is 180deg off i just saw the video, i agree with you.
