Post by gy6luver on Oct 17, 2011 9:19:29 GMT -5
im going to zip over to auburn to get my nuts cracked and ill come back and check on this, this is to much of a dead end to worry about atm, anyone that comes up with anything let me know SOMEONE out there bought a ventospeedo and wired it at one time or another,
im sure of it
Post by gy6luver on Oct 17, 2011 13:02:57 GMT -5
well today so far made some progress found people who WANT TO HELP ME at the local garage, we loosened the variator and clutch 17mm bolts, ( i would have gone to my mechanic that loosened them in the first place but he was a bad wording putz and said he "had no room in his driveway" for me to do the work) well bad word HIM then ill NEVER send another person to that bad worder again.
and i have other people who say "ill call you in a bit" and then they dont bad wordING CALL at all, people in this life can be such two faced motherbad worders
anyway the rollers are in at least, the gears are spilled out in the driveway im awaiting someone who gives a damn or has two bad wording bits of IQ to help me in what was supposed to be "plug and play"
right, the reserve tank is also fixed, ill have photos later
so far rollers were a total of
12 grams X 6 = 72 grams OUT 14 grams X 6 = 89 grams IN
not sure what difference if any that will make, also found a washer behind the variator wheel, thinking i should throw that out for some reason!
more later if i dont kill somebody first .....
Post by gy6luver on Oct 17, 2011 14:52:39 GMT -5
right no im SUCK AND FRIGGIN TIRED of sitting ALL Day waiting for someone to help, it pissesm e off to the max, id do this all myself and say to hell with everyone else if i could it would get done ALOT faster! right now im being dicked around by people who do not know how important this trip really is
my current stuck is everyone CLAIMED the gears were supposed to be plug and play, they were mostly FULL OF sh!t, the bottom smaller gear slides into place fine, the big gear though wont go on the spindle, if i dont hear from someone soon on this i am going to hit it with a hammer,
im just losing patience of peoples lack of caring and total lies!
Post by 90GTVert on Oct 17, 2011 15:40:08 GMT -5
A pic of what's not working might help. I've never done a 150 gear swap or split the gearcase open for any reason so I dunno what you're even looking at exactly. If it's a splined section that won't fit, check the number of teeth vs splines to be sure it matches up. If it looks like it should fit, check for casting flaws on either part.
The heavier rollers will drop RPM. That could be a bad thing with the gears. If you get the gears installed and it's sluggish, go back to 12g.
Post by gy6luver on Oct 17, 2011 16:25:41 GMT -5
ok brent,
im taking break from scoot stuff for tomnight im overloaded, will post a pic tomorrow, thanks for all the help i need a breather
Post by 90GTVert on Oct 17, 2011 16:33:14 GMT -5
Sounds like the best bet. I think we've all been there before.
Post by gy6luver on Oct 17, 2011 22:22:09 GMT -5
Sounds like the best bet. I think we've all been there before. 3 movies and im raring to go again (make that three AWESOME movies in their own right) photos of the current days progress (or lack of on the way
Post by gy6luver on Oct 17, 2011 22:45:34 GMT -5
today not a whole lot got done, as i said before i got the rollers done so i wont repeat myself, the gears hit a snafu and help was nowhere to be found at all today so i took a break from it, the reserve tank is full of gas and the fuel system has now been tested and is functioning fine photos from today are here i wish to thank www.partsforscooters.com for sponsoring the gears and the rollers that were worked on today! www.dropbox.com/gallery/35382354/1/Even%20closer?h=539d12
Post by 90GTVert on Oct 17, 2011 23:38:06 GMT -5
Well the pic helps. So it appears it's a splined gear. It should slide on easily. If not, something is wrong with it or the shaft it's going onto. First the obvious, try flipping it over and see if it starts. Then again I go back to thinking you should inspect it carefully for flaws or any sort of mismatch. If there's something wrong that you can't file or fix somehow, you might need to see if you can get an exchange or see if PFS has any advice.
Post by gy6luver on Oct 18, 2011 15:25:56 GMT -5
the clock has restarted, its going to be a beautiful fall foliage ride in the eastern USA at least till northern virginia then it will be shorts and t shirt time!
Post by gy6luver on Oct 18, 2011 15:26:37 GMT -5
Well the pic helps. So it appears it's a splined gear. It should slide on easily. If not, something is wrong with it or the shaft it's going onto. First the obvious, try flipping it over and see if it starts. Then again I go back to thinking you should inspect it carefully for flaws or any sort of mismatch. If there's something wrong that you can't file or fix somehow, you might need to see if you can get an exchange or see if Parts For Scooters has any advice. gears were 20 splined, shaft was 19 splines, lol new ones on the way from sponsor
Post by bigkahuna427 on Oct 18, 2011 15:35:04 GMT -5
I just looked at your website and I am here in Maine are you? When I said wish I was there I guess I pretty much am. Funny I have just been emailing Ryan about some parts he has on CL.
Post by gy6luver on Oct 18, 2011 15:43:15 GMT -5
I just looked at your website and I am here in Maine are you? When I said wish I was there I guess I pretty much am. Funny I have just been emailing Ryan about some parts he has on CL. where are you maybe you could help me figure out the fuel gauge after all, its a small world fyi im in notsiwel read it backwards lol
Post by bigkahuna427 on Oct 18, 2011 15:45:36 GMT -5
South Portland
Post by 90GTVert on Oct 18, 2011 16:39:54 GMT -5
That break did the trick. Came back with a clear head and found the problem and no one needed to be called names. lol :thumb:
