Post by Zino on May 27, 2020 19:36:35 GMT -5
Post by Zino on May 27, 2020 20:11:02 GMT -5
After Dialing in the Clutch I Worked on the Variator . To match better to the Next R I bought a Malossi Torsion Controller . It Just helps keep the Contra spring from Binding But also does Take the Tension up a Notch. This allowed me to use the White Contra to keep the Belt from Slipping. I feel that anything above Just enough tension on the Contra in a Street daily Rider Build is just extra Heat and wear and tear on the Belt. Racers want the downshifting of the Higher Tension Contra's for coming out of corners . Here are My Tuning results as You can see My Butt Dyno decided that The 5 grams were to light and got me close to the same topend as 6 and 5.5 but it was out of the powerband at the top . Wasted Rpms for no extra speed . The 6 grams got me the top end but acceleration was lower than 5.5 grams . I just did a quick run with my gps to give me speeds on the same road in both directions 53ish one way 55ish the other All 3 of these weights worked When I hit the throttle wide open the rpms held steady all the way up. The next step is I check for full belt travel on the 5.5 grams By Taking a sharpie marker and running a mark from the inner edge of the variator to outer edge . Go Full Blast down the Road and see what is left .I am getting under a # 2 pencil lead size which is 2 mm on both Inner and Outer Edge . That is what I shoot for .
Post by aeroxbud on May 27, 2020 20:11:30 GMT -5
That sounds really nice for a short pipe.
Post by Zino on May 27, 2020 20:15:55 GMT -5
It is a Little Throatier than The Malossi Wild Lion . It is Like the Yasuni R compared to the Next R . My Kids could definetly tell that I had Changed To the Yasuni when I came home . My 12 year old son Loves that Yasuni sound .
Post by oldgeek on May 27, 2020 20:23:39 GMT -5
I have the same TK pipe on my vertical blue Kymco ZX I love it, but it is definitely on the loud side. Probably as loud as any full pipe I have tried.
Post by Kenho21 on May 27, 2020 23:23:40 GMT -5
That’s a nice sounding pipe. Price is right too as long as it’s a decent performer.
What language is that in the video title Zino?
Post by Zino on May 28, 2020 0:20:20 GMT -5
That’s a nice sounding pipe. Price is right too as long as it’s a decent performer. What language is that in the video title Zino? Its a Half wave Street pipe low 9s it will peak out at with a wide powerband . That would be German . I have been reading alot of European sites over the Years Google Translate is amazing . I never posted on any just sucked up Info on tuning. Tuning Theory in Europe has its Differences . They Highly Port alot of Sport kits so they can run Hotter Pipes . Malossi Sport paired to a Yasuni C16 is a combo you see often Dr 70 ported out so it outperforms its more expensive brother Top Performance Trophy Polini Contessa ported to the Corsa .
Post by Zino on May 28, 2020 0:58:47 GMT -5
So I ran That Set Up For a Year . Malossi Sport ,Tecnigas Next R ,Polini Variator ,Malossi Delta Clutch Scootertuning just had to have another Black Friday Sale . And the Yasuni R and A Stage 6 19mm Dellorto Carb Malossi Variator some Jets and Other Odds and Ends on the way for This years up grades. I took a Brand New Athena Sport Kit in Trade for me helping a buddy out Last fall. So I planned on swapping to Athena the Yasuni R Malossi Variator and then adding the Carb. Targetting a Set Up that still should live around 10 k rpms or under.
Post by Zino on May 28, 2020 1:11:30 GMT -5
Overrange 1/2 price Blow Out Deal at Parts for Scooters . Quite a few of us were playing the Malossi Furia Overrange Lottery They only had one . I did not win that one . I came Across this Thread 49ccscoot.proboards.com/thread/24543/top-performance-td-belt-lengthI Installed this just Last Month . It Kicks Harder at takeoff with the lower gearing If you already have kitted and piped and thrown on gears this would be a next mod If you want the budget overange pick up these parts . I picked all these up at Dynoscooter . malossi variator part 5177075 ,malossi fan 617152,malossi shim kit 812036 ,top performance torque driver polini belt 248.041 The polini belt after properly shimmed left less than 2 mm on the outer edge front pulley and hit rock bottom on the inner edge . By doing this you go from stock pulleys of 93 mm on front and 115 mm on back to the malossi at 97 mm on front to 122 mm with the top performance pulley . Going from the Polini Variator to The Malossi Variator was a push as far as top speed .
Post by Zino on May 28, 2020 1:22:38 GMT -5
Did Not have Time Yet To Fully Build Up the Zuma had to Get My Vino Kitted . I had to get the Yasuni R on . The Yasuni Power Band is wider so I just slapped it on the trans tune works as is the way it was set up . My Son Loves the sound It definetely is Throatier than the Next R . They can hear me coming from a block away . The Next R revved to as high 9400-9500 with the Malossi Kit The Yasuni is hitting 9800-9900 So my Mph are up about a mile or so to 55 plus.
Post by aeroxbud on May 28, 2020 6:25:12 GMT -5
When I changed from the next R, my slider came with. To a Yasuni R, it was about 5MPH faster on top end. But pulled so much better everywhere.
Post by Zino on May 28, 2020 8:24:16 GMT -5
I havent Gpsed the Yasuni R it yet so I might be faster up top. I agree It is snappier all the way through the REV Range . I just guessed based on Rpm. The US Speedometer for the Zuma stop at 40 Mph and It buries at 50 Mph . It is Raining the next few days ,So It feel like time to put on the Athena on.
Post by Zino on May 28, 2020 8:28:23 GMT -5
Alot of Guys will paint thee exhaust with VHT paint for Rust Prevention. Here is another Option Just buy some MOP N Glo and Brush It on Regularily . The Heat of the exhaust Turns the layer of Mop N Glo a Bronze Color .
Post by Kenho21 on May 29, 2020 9:05:01 GMT -5
That’s a nice sounding pipe. Price is right too as long as it’s a decent performer. What language is that in the video title Zino? Its a Half wave Street pipe low 9s it will peak out at with a wide powerband . That would be German . I have been reading alot of European sites over the Years Google Translate is amazing . I never posted on any just sucked up Info on tuning. Tuning Theory in Europe has its Differences . They Highly Port alot of Sport kits so they can run Hotter Pipes . Malossi Sport paired to a Yasuni C16 is a combo you see often Dr 70 ported out so it outperforms its more expensive brother Top Performance Trophy Polini Contessa ported to the Corsa . I had no idea you were German Zino. Explains some of your expertise. Europeans have it good for scoot stuff. My family is from Idar-Oberstein.
Post by Zino on May 29, 2020 10:59:00 GMT -5
No I'm not German Google Translate is what helped me read the posts on the various sites . Vacationed a little bit in Italy That is Scooter Heaven . When I went around and saw all the different Scooter Yamaha Aeroxe's ,Jog ,Slider,Piaggio Zip's Aprilla ,MBK. I kept trying to figure out how do I get Just one of those things home. Damn Carry On Bag Limits . I am actually Irish and Indian ,My wife is full German so that is close I come .
