gutiwarrior
Malaguti F12 Project Wife
Post by gutiwarrior on Aug 13, 2020 15:39:14 GMT -5
gutiwarrior
Post by gutiwarrior on Aug 14, 2020 18:38:27 GMT -5
In line 90C fan switch installed. Waiting for fan and some more components
gutiwarrior
Post by gutiwarrior on Aug 16, 2020 19:51:46 GMT -5
Front end air vents mocked up for the radiators. Second one coming in tomorrow.
Post by aeroxbud on Aug 17, 2020 17:26:05 GMT -5
I like the vents. Quite subtle from the front. I guess you won't really know how well they work, till you try them.
gutiwarrior
Post by gutiwarrior on Aug 17, 2020 18:18:01 GMT -5
I like the vents. Quite subtle from the front. I guess you won't really know how well they work, till you try them. I know the one side I had to open up from the 3 holes to connecting then all. One radiator wasn’t enough due to its size but we shall see what two will do and properly tuned! Right now I’m running a 89 main jet on a stage6 street race which I think may be a little small and maybe contributing to the added heat at wot.
Post by aeroxbud on Aug 17, 2020 19:02:18 GMT -5
It's a lot easier to make bigger a cut out if needed. Than make them too big. My jog RR used to have one radiator, about that size. It did get quite hot a few times in slow traffic. But the air vent was smaller than yours are.
gutiwarrior
Post by gutiwarrior on Aug 18, 2020 15:01:20 GMT -5
Alright. All hooked up and replaced my pumped studs with actual studs and rubber grommets. With both radiators I was hitting 155 around town. At wot I barely saw 170. I need to tune the carb a little and hold it open and see where it stops BUT big difference with two radiators. The setup is coming along good!
Post by jason1976 on Aug 31, 2020 6:00:22 GMT -5
Post by jason1976 on Aug 31, 2020 6:02:07 GMT -5
Where did you find the side cover 1 for your scoot? I just picked up a 2001 Vino that the plastics are pretty much trashed. I'm having a hard time finding the rear section.
Post by azurelimits on Sept 12, 2020 20:29:16 GMT -5
Please tell me more about the front end swap. I am trying to do it on my 04 vino.
Post by hellish100 on Sept 13, 2020 9:30:27 GMT -5
Wolf Islander steering stem with 26mm NCY Legs. I have the same setup and is available for sale. DM me privately if you want more info.
Post by Mole2tUVY on Jan 16, 2021 13:38:57 GMT -5
Just dug my way out of the borrow. Man I have missed out on this build. Looks good man love what you're doing its inspired me to restart my vino build. Sorry I never replied back to you man. Its been a long time since I've logged in.
Post by viciousvino on Jan 16, 2021 23:21:09 GMT -5
I’m enjoy your build thread... Glad to see another front disc vino Let us know how that rear disc brake kit works out... I was looking st that but was hesitant. Did you ever figure out the Stage6 bell? I had mine milled down, I had the same issue with minimal threads showing and it is perfect. Here is a pic of my vino build postimg.cc/gn5qKgMbbr] Used malaguti stem, front shock, rims front and rear foe my conversion
gutiwarrior
Post by gutiwarrior on Jan 19, 2021 18:37:43 GMT -5
Hello world! Been some time since I been on here. Vino is running strong. Stuck a stage 6 street race liquid cooled setup and a yasuni r pipe. Been going gooooood.
why stop there right? Athena Evo, different pipe, and a mvt ignition coming in the mail! Biggest kit I could do without changing crank and a lot of other things. Should be the next big jump coming from street race.
stay tuned!
