Post by tiny on Jun 9, 2020 23:15:40 GMT -5
Top speed that I've been to on my Vino was 90kph or 59 mph. With the longer rear shock I we can still use center stand but the rear wheel is just touching the ground. You might be able to slip a piece of paper between the tyre and the road
gutiwarrior
Malaguti F12 Project Wife
Post by gutiwarrior on Jun 9, 2020 23:19:38 GMT -5
Top speed that I've been to on my Vino was 90kph or 59 mph. With the longer rear shock I we can still use center stand but the rear wheel is just touching the ground. You might be able to slip a piece of paper between the tyre and the road What size shock did you get?
Post by Zino on Jun 9, 2020 23:42:46 GMT -5
gutiwarrior
Post by gutiwarrior on Jun 10, 2020 23:38:28 GMT -5
Koso my bike has a following: primary: 13/48 = 3.6923 secondary: 13/42 = 3.2307 Ratio: 11.9287
Post by Zino on Jun 11, 2020 0:37:13 GMT -5
If you get those malossi gears post up your install with pictures. I would like to see it come together . And it would probably push me into doing them . I did the math wrong 40/17 is 2.35 x 3.23 = 7.6 gear ratio That is alot of potential going from 11.92 to 7.6 . If it werent for the wall of wind We would be pushing 80 mph .
gutiwarrior
Post by gutiwarrior on Jun 11, 2020 6:19:06 GMT -5
That’s a HUGE difference. If the kit will push it while putting some lighter rollers maybe. Earlier the kit did 55.5gps and I saw 10,600rpm behind a car so we will see! For sure brakes after this lol I have the gears coming along with a bigger manifold and reeds
Post by oldgeek on Jun 11, 2020 6:57:04 GMT -5
11.92 is GREAT 7.6 is way too much, even for the lightweight VINO Can't hurt to try it though. I tried 7 something gears on a heavier scooter that had 99cc's There was not enough power to pull any faster.
gutiwarrior
Post by gutiwarrior on Jun 11, 2020 7:24:08 GMT -5
11.92 is GREAT 7.6 is way too much, even for the lightweight VINO Can't hurt to try it though. I tried 7 something gears on a heavier scooter that had 99cc's There was not enough power to pull any faster. I AGREE! But hey. Ideally I could find the right gears but everything was different for this engine. With the small 10” tires it should push it to 66 at least. According to the other guy who used these gears. My plan is to lighten the rollers so my takeoff is still good and also can push the gears up top. Won’t hurt to try.
Post by Zino on Jun 11, 2020 7:25:18 GMT -5
Post by Zino on Jun 11, 2020 7:27:34 GMT -5
With my Zuma going from 14.66 to 11 to 1 I did have to drop weights 1/2 gram or to get them to spin up to the same rpm range .
gutiwarrior
Post by gutiwarrior on Jun 11, 2020 7:29:57 GMT -5
They don’t have many options for gears without buying a bunch and trying. But these little bikes seam to be pushing the mid 60s. Also his build has a corsa in it. Lol tad more power the the malossi sport. I NEVER was aiming for power and speed with this bike. I hot use to it and felt the potential and said F IT. We are going.
gutiwarrior
Post by gutiwarrior on Jun 11, 2020 7:35:19 GMT -5
They don’t have many options for gears without buying a bunch and trying. But these little bikes seam to be pushing the mid 60s. Also his build has a corsa in it. Lol tad more power the the malossi sport. I NEVER was aiming for power and speed with this bike. I got use to it and felt the potential and said F IT. We are going.
Post by Zino on Jun 11, 2020 7:36:37 GMT -5
Well we will find out soon what a malossi vino build with Gears can do
gutiwarrior
Post by gutiwarrior on Jun 11, 2020 7:40:30 GMT -5
Well we will find out soon what a malossi vino build with Gears can do If it will do 70 I will shit myself. My malaguti 150 does 70. Lol
