Post by 190mech on May 11, 2021 19:26:39 GMT -5
Dig into that carb,or replace it and it'll likely fire right up...
Post by thxcuz on May 11, 2021 20:08:18 GMT -5
Dig into that carb,or replace it and it'll likely fire right up... Any suggestions? Would an sha clone do the trick? I think I have 3 of them somewhere
Post by geoffh on May 15, 2021 14:46:37 GMT -5
When you get round it :)there is a cracking after market seat cover available 278218 seems to be the key number it,s made by "tailored" there's a few listed in the U.K.flea bay site from £11 to £20,pays your money and throw the dice.I got mine from brooks barn pembs.
Post by thxcuz on May 15, 2021 20:10:26 GMT -5
Quick question while I got you here- my low oil light is on (I’m using premix in the tank) that wouldn’t prevent it from starting would it? I wouldn’t think a scooter from when I was in high school would be that high tech
Post by aeroxbud on May 16, 2021 5:15:09 GMT -5
No it wouldn't stop it from starting. It's just a low level warning light. I just took all the oil stuff off. But you could just remove one wire from the sender. It would remove the annoying light.
Post by geoffh on May 16, 2021 7:58:38 GMT -5
Ditto what aeroxbud said,but these things need to be completely built up to run it,s a PIA sometimes but mine won,t go without "feeling" whole.it,s not high tech but it,s not steam engine tech 30 years of being around will show in some unexpected fashion.
Post by thxcuz on May 22, 2021 7:37:21 GMT -5
Well gang, not much progress in getting the old gal to start. As matter of fact - what’s the opposite of progress? Regress? I’ve made a lot of regress on this scooter. It gets spark & carb is clean. I’m thinking somehow fuel isn’t flowing from the carb to the engine or I have poor compression. I haven’t done any tests, thumb or otherwise. Or it could be bad seals. I’ve dealt with that on a QT 50 a few years ago. 33 year old rings and seals are bound to fail I recon.
I’m on vacation next week so I’m planning to drop the engine and give it a real good looking over. Testing the compression, inspecting the reeds, checking the exhaust for blockage- the whole Megillah. I’m determined the get this pig running. Fortunately I have a really good Yamaha dealer not too far from my house. They’re never not had a part I need in stock or at least have been able to find a substitute.
I always leave there with a smile and a lighter wallet.
Post by geoffh on May 22, 2021 9:57:39 GMT -5
Strange,different dealerships different worlds maybe,I won,t go to my local dealer they think 50cc = trailer trash,good plan for the checks make sure your crankcase is clear of gunk,get your best mate to syphon it out using a drinking straw Geoff
Post by thxcuz on May 24, 2021 12:07:43 GMT -5
Post by aeroxbud on May 24, 2021 12:29:18 GMT -5
That doesn't look bad.👍
Post by thxcuz on May 24, 2021 13:33:09 GMT -5
Who’s got 2 thumbs and broke the piston? This guy Well, I may as well kit it since I’m buying a new piston. Affordable suggestions?
Post by geoffh on May 24, 2021 14:44:35 GMT -5
I see the logic but I would buy a piston for the 50cc barrel,putting a BBK on it now might just push you into a dark room of confusion,the pistons are cheap enough and the Same as the modern horizontal engine.Other wise your engine looks good to go once it,s cleaned and rebuilt.
Post by thxcuz on May 24, 2021 14:57:29 GMT -5
Post by geoffh on May 24, 2021 15:08:33 GMT -5
Not for me I,d get one from my scooter parts specialist,Parts for Scooters are members on here quality parts and service to the USA I am led to belive,but I have a dislike of amazon.
fugazliv is Matt's user name on here sure if you p.m. him he will sort you out Matt =parts for scooters
Post by thxcuz on May 26, 2021 7:20:22 GMT -5
I’m sure this has been covered before but I’m having trouble wrapping my head around how the auto lube works. The manual I have assumes that I have the intelligence above a 4th grader and they couldn’t be more wrong
First off, is it only gear driven or is it cable driven? I recall the qt50 I had was cable driven.
Second, I was attempting to pull it to inspect it and it would not come out. Do I need to split the case to get to it?
I’m sure it’s just as easy to block it off and run pre mix but now I’m curious and as I said, the manual isn’t too terribly helpful
