Post by milly on May 26, 2021 18:26:40 GMT -5
Thank you aeroxbud but solved the problem after going through the switchgear and found it was the relay which I replaced with one from a dead BMW. Did the carb this evening, had bit of water in it cleared the jets out but still not right.. Now I think about it pilot jet I could not see daylight through it when looking down the end. Maybe my problem or just to tired and need sleep.
Post by milly on May 26, 2021 18:31:09 GMT -5
Yep to tired didn't read that properly aeroxbud I got some idiot light bulbs earlier today. 😫 💤
Post by milly on May 28, 2021 15:45:26 GMT -5
Post by milly on May 29, 2021 16:16:36 GMT -5
Up and running little bit spluttery on road test but think maybe cap not secure will check tomorrow.
Post by milly on May 31, 2021 8:32:46 GMT -5
Still sputtering at mid throttle but ease of and it pulls through till have to slow down again. New carb so will need check other bits but not today to hot here about 74f even the winds not cool and to tired. Time for a siesta
Post by aeroxbud on May 31, 2021 10:49:56 GMT -5
Sounds like the needle needs adjusting.
Post by milly on May 31, 2021 10:58:03 GMT -5
Sounds like the needle needs adjusting. Too low maybe
Post by milly on May 31, 2021 14:52:41 GMT -5
Thank you aeroxbud I put needle on top notch runs 100% better now. Maybe bit of tuning as cuts out at full throttle after a while but that is another day. Mot in the morning 🙃
Post by aeroxbud on May 31, 2021 14:59:21 GMT -5
That's good. Let's hope it goes through. Fingers crossed.
Post by milly on Jun 1, 2021 3:35:59 GMT -5
Mot sorted, advisory on sticky front disc
Post by milly on Jun 1, 2021 7:13:04 GMT -5
Think now sold it to the owner of the coffee shop.
Post by aeroxbud on Jun 1, 2021 17:36:15 GMT -5
He knows you will be giving him the money back each week. 😉
Post by milly on Jun 1, 2021 18:25:33 GMT -5
Indicators stopped working sorted that now no spark. No rush see what's happening tomorrow morning with it.
Post by milly on Jun 2, 2021 6:20:28 GMT -5
Sold and he is happy to finish off the rest now running and he has tried it.
Post by milly on Jun 18, 2021 11:51:18 GMT -5
Now blue meanie has entered my life again I found the battery dead yesterday with only 6v in it. Today after a slow charge I found out it was the starter relay I had used from a BMW causing the parasitic discharge. New relay ordered just plug this one in when needed.
