Post by Zino on Nov 30, 2021 22:36:37 GMT -5
Wiscootsin hooked me up with a Roughouse engine from a salvaged scoot I will up load pictures of the trans and engine tear down .
Post by Zino on Nov 30, 2021 23:34:11 GMT -5
There is No locking tool for the roughhouse variator . So I use a dewalt impact with a 14 mm socket. On the variator nut I could also use it for the clutch nut For the clutch I like the buzetti 39mm wrench BU5476 part number for taking off and putting on the clutch bell nut and the larger 39mm clutch nut . Clutch bell Locked in place for taking off or putting on with a torque wrench . With a couple taps on the cement floor this works for getting off the clutch nut and tightening it back to proper torque .
Post by Zino on Dec 2, 2021 19:45:26 GMT -5
torque wrench work around before the first time you take the clutch nuts and variator nuts make a mark with a permanent marker from inside to the outside like this This way at a glance you can tighten to the proper torque
Post by Zino on Dec 2, 2021 19:56:29 GMT -5
behind the variator There is the starter gear then a spacer and then a crankshaft oil seal this seal has a slight leak of oil residue and needs to be replaced otherwise the cylinder would eventually burn up.
Post by Zino on Dec 2, 2021 21:28:10 GMT -5
After taking out the 6 bolts it took a couple light taps on the cover with a rubber mallet to loosen it so I could pull off the cover The primary gear shaft and cover Too get the secondary gears out. Take the back tire off and I use a block of wood against the drive axle on the tire side and tap lightly to gently push loose of the oil seal in the gear case .
Post by Zino on Dec 5, 2021 10:31:08 GMT -5
new gears to pres on stock gears 52/13 primary and 44/13 secondary 13.53 final gear ratio Malossi Secondary part # M6714744 42/15 tooth count 11.2 final gear ratio This will put me close to the 11 to 1 ratio , I shoot for on the Yamaha Zuma to maximize top end performance with still having good take off . On the Zuma it typically added 5-10 mph top end With a similar 20% increase in Gear Ratio . Added benefit is the engine works less hard at cruising speeds. Malossi Gears on the right in both pictures will need to be pressed on .
Post by islandscrub on Dec 9, 2021 2:49:12 GMT -5
Any idea what makes the RH gearbox different from a chinarelli? At a glance it looks similar, but I guess they all would anyway..
Post by Zino on Apr 10, 2022 18:24:53 GMT -5
Island They look similar to me
I installed 17.5 dellorto with the flange L-DEL1438 ordered from TreatLand It hooks right to the roughhouse flange ,You also can bolt the stock autochoke to it . It does work with the stock throttle cable . I pulled the snorkle out of the air box . With the colder dryer weather The jets I settle on for now might be a notch rich for summer 90 main jet was a little rich 88 main sounds like mad hornets and feels close to right and had better speed then the 90. Temps are lower than the stock carb I am peaking around 280 degrees . Worked down from top of the needle 2nd from the bottom clip was the richest setting with the best throttle response. The 35 pilot is a little big I have it at 3 3/4 turns out to get the fastest and smoothest idle . Cruising at part throttle tempatures are 240-270
Treatland has a 15% off sale So I ordered some odds and end parts along with a 33 and 34 pilot.
Post by Zino on May 1, 2022 16:32:50 GMT -5
Post by Zino on May 1, 2022 17:06:50 GMT -5
Once you get the seat off the carb is easy to work on At the top of the picture the tube covered with the spring is the oil feed . It feed the mainfold directly so when swapping to a aftermarket carb . You can leave just like stock if you want to continue to use oil pump The throttle cable take a little patience to work through the cap on the top of the carb The auto choke is easy to swap over from the stock carb to the dellorto 17.5 Just 2 screws to take off pop the choke off press it in new carb and tighten down the 2 screws.
Post by Zino on May 1, 2022 17:42:17 GMT -5
When swapped to the bigger carb . Better Temps more RPMS .
Stock Carb Temps drop dramatically . I was touching 320-330 with stock carb at wide open Long runs . Mid throttle was 280-300 Peak rpms 9000-9100
With Dellorto 17.5 I am running at 280-290 degrees on long wide open runs and Mid throttle 240-260 Peak Rpms 9300
Both Carbs are set for a tad rich at all throttle positions for daily driving . The Snorkle is removed from the Air box .
Stock Carb with snorkle in Wild Lion Exhaust Stock Bore I settled on 82 main 38 pilot without shimming needle
Dellorto Wild Lion exhaust with stock bore I have settled on 88 Main 33 pilot 2 1/2 turns out 2nd richest needle position.
These are my colder weather under 50 degrees settings for the carbs so they will be richer in the summer temps.
Post by aeroxbud on May 1, 2022 18:10:06 GMT -5
That's a coincidence. I have just fitted a Dellorto 17.5 to the aerox. I found like you the 38 stock pilot jet was way too rich. Even a 36 had quite a bit of stuttering at 8th throttle. Runs great with a 34 though.
Post by Zino on May 1, 2022 19:08:03 GMT -5
The Stock 35 I could not get any real control over the air screw , I was closer to 4 turns out. I like being a little fat on the bottom but that jet was way to rich even with snorkle out of stock airbox .
Swapped in the 33 and 2-3 turns is where the idle smoothed out .
These were all Genuine Dellorto Pilot Jets .
Post by yambw’s on May 2, 2022 5:01:04 GMT -5
I have not long installed the 17.5 dellorto and I have the snorkel out with the hole opened up a notch, stock 38pilot that came with the 17.5 carb 97 main jet and the air/fuel screw 3 and a quarter turns out guess that means the idle jet is a bit fat but no spluttering, plug looking good after that 80mile ride
Post by Zino on May 2, 2022 8:07:30 GMT -5
The 35 was functional just a notch rich. I have been fine tuning the main and pilot before I swap cylinders .
Fine tuning the pilot .
By blipping it on a well warmed up engine . The idle either hangs and then drops down which is a tad lean The idle Drops below and then cleans up and rises back to idle speed which is a tad rich the idle drops right back to idle speed.
The 35 pilot at 3 1/2-4 turns out was dropping the idle speed the 33 pilot at 2 1/2 - 3 turns out the Idle falls right back with no hang. I then dial it in by 1/8's for best transition to needle.
Fine Tuning the Main When I get to the richest jet that gives best Top speed . For a Daily driver I would be done .
A race day trick is run wide open and then close the throttle by 1/4 to 1/8 so you just go slightly on needle this richens you up temporarily .
3 things happen Your Speed rises You are a notch lean on The Main Your Speed drops quick you are a notch rich on the Main If your speed drops slow or holds for a second You are close to perfect for that days temps and humidity .
