Post by yar1993 on Oct 6, 2021 19:32:45 GMT -5
My bad missed your post.
Post by yar1993 on Oct 6, 2021 19:37:39 GMT -5
I already have jet kit haven’t look into or really thought about a temp though.What’s good for temperature?
Post by Zino on Oct 6, 2021 19:48:42 GMT -5
I use trail tto surface mount with a 14mm spark plug ring . Battery last for 5 years plus . I also bought the 48 " extension so I could mount it up by the handle bar. I bought the directly from trail tech and amazon
I have tried to use the cheaper knockoff ones on Amazon but the batteries run out fast .
Post by yar1993 on Oct 6, 2021 19:55:59 GMT -5
Cool I’ll look into it I’m trying not to spend to much at on time but a temp gauge sounds like a good thing to have.
Post by yar1993 on Oct 6, 2021 20:00:49 GMT -5
Post by Zino on Oct 6, 2021 21:42:23 GMT -5
That is the same malossi cylinder I run . Scooter Swap Shop also sells the trail tech temp gauge and ncy golden variator .
I havent bought a ton from them . But they have answered my questions by email and phone .
Post by yar1993 on Oct 6, 2021 22:19:09 GMT -5
Looked at scooterpartco and believe I found them on eBay think I’m just gonna get the kit from them.
Post by yar1993 on Oct 6, 2021 22:23:35 GMT -5
Post by yar1993 on Oct 6, 2021 22:25:30 GMT -5
Not the link I wanted to send but I would say it’s definitely them.
Post by snowmeiser on Oct 7, 2021 6:10:09 GMT -5
That’s the same place I bought my Molossi kit, don’t waste your time with the cheap gauges as I found out the hard way. I bought the trail tech gauges for both of my scooters. They work flawlessly . The only thing I still have not found ideal location to mount to the roughhouse. I just have them taped to the floorboard.
Post by Zino on Oct 7, 2021 7:33:35 GMT -5
Post by yar1993 on Oct 7, 2021 10:47:01 GMT -5
I ordered the bbk last night looks like it comes with reeds to did y’all use them?
Post by Zino on Oct 7, 2021 21:22:28 GMT -5
brent has a pretty good install process here . It covers all the main steps and the finer points like chamfering ,torque wrenches,sealants ,lube while assembling . Just go slow take alot of pictures so you can retrace your steps on install . Feel free to post up your pictures to help out the next guy with his install . You will find also having a side stand can help give a better angle installing the piston clips and cylinder head . 49ccscoot.proboards.com/thread/556
Post by yar1993 on Oct 7, 2021 22:32:01 GMT -5
Thanks pretty sure I’ve read that thread but was a long long time ago I’ll probably just put the motor out to do it then I can set it on a table or whatever.I’ll try and keep y’all up to date when I start getting into it.I do no one thing clutch springs are the devil.
Post by aeroxbud on Oct 7, 2021 22:56:28 GMT -5
You've found the joy of fitting stiffer clutch springs then! A spring puller really helps.
