Post by yar1993 on Oct 29, 2021 9:50:53 GMT -5
Just put in a 88 main helped a little on top end but what happens is when I hit around 50mph on the scooter gauge feel like my rpm and speed drop till I hit around 40 mph then rpm picks back up again.
Post by yar1993 on Oct 29, 2021 10:00:51 GMT -5
Just put in a 88 main helped a little on top end but what happens is when I hit around 50mph on the scooter gauge feel like my rpm and speed drop till I hit around 40 mph then rpm picks back up again. Also my temp didn’t get above 320F little higher but still way better than the temps I was hitting before.
Post by Schlappy on Mar 30, 2022 3:54:02 GMT -5
Nice Bike! I have the same color on my 2019 RH50 sport. I need to get a temp gauge as well and was hoping someone had a link to the trail tech. You say you have a 21mm carb ? I'm still using the stock 17.5 mm carb and airbox. I'm still probably way off on my tuning somewhere to some extent. I got a tach but need the temp
Post by aeroxbud on Mar 31, 2022 4:49:19 GMT -5
Post by Schlappy on Apr 1, 2022 21:50:27 GMT -5
That's the same one I have on the way. Aye your link says it wont fit my bike but if it's 14mm after all then it should be good to go. Beyond that here's the proof I do indeed have a similar bike:
Post by yar1993 on Oct 7, 2023 21:37:06 GMT -5
Been awhile but at this point I think I need a different pipe and carb setup runs great but top end suffers can’t stay at top rpm will slow than pick back up then slow again etc..
