Post by yar1993 on Oct 17, 2021 22:17:37 GMT -5
Put the new plug in today didn’t really get a chance to test to much but my temp got up to 344f on the way home from work only a mile and a half.Think im going to look into some sliders or some different rollers.
Post by Zino on Oct 18, 2021 7:52:20 GMT -5
Wide open might be close to Ok If the temp will hold and level off .
What is your current jetting ? On main and pilot ?
Most soft seizes happen when coming off full throttle runs . So make sure your off wide open throttle positions are rich enough .
One size richer on the pilot jet richens the whole range .
Post by yar1993 on Oct 18, 2021 10:56:34 GMT -5
90 main and stock pilot I believe it’s a 38 not a 100% on that.
Post by snowmeiser on Oct 19, 2021 6:28:25 GMT -5
I would move the clip down two places or add a couple of shims (washers) under the needle to raise it to get the mid range safe . You can always go back one if it’s to rich . Better be safe than sorry.
Post by yar1993 on Oct 19, 2021 13:00:11 GMT -5
I would move the clip down two places or add a couple of shims (washers) under the needle to raise it to get the mid range safe . You can always go back one if it’s to rich . Better be safe than sorry. I found a little piece of plastic probably about the thickness of a dime to shim it with way to rich now might work if I go down on the main jet.I also took off the cover over the fan I haven’t been over 344F at WOT but can only hold it for around 1/2 a mile around here.
Post by yar1993 on Oct 19, 2021 13:04:39 GMT -5
Also been looking at the 6 sigma jet kit thinking it might be worth it to pick one up.
Post by snowmeiser on Oct 19, 2021 14:19:38 GMT -5
I just got mine have not installed yet. But seems worth while . Comes with nice shims ,four main jets and pilot jet . A lot of instructions
Post by snowmeiser on Oct 19, 2021 14:23:29 GMT -5
I also would try half the thickness first before I went down on the main jet.
Post by yar1993 on Oct 28, 2021 0:37:50 GMT -5
Ok so I got the ncy super trans kit using the ncy clutch bell,stock clutch with polini blue springs and the dio drive boss and the golden variator with 6 and 7 gram roller’s.Stock contra spring also have a really nice 0-30 now and my temps have dropped a good bit most I’ve hit is 301F lately.I have lost some top end though feel more comfortable down jetting now maybe that’ll help on the top?
Post by snowmeiser on Oct 28, 2021 4:17:23 GMT -5
What RPMs are you running ? Try 1/2 gram heavier weight to see if you get more top end and it will probably bring your temps up a bit.
Post by yar1993 on Oct 28, 2021 10:22:31 GMT -5
What RPMs are you running ? Try 1/2 gram heavier weight to see if you get more top end and it will probably bring your temps up a bit. I don’t have a rpm gauge I did try a heavier roller took all the low end I want had great top end before with the same rollers I’m using.
Post by repherence2 on Oct 28, 2021 10:50:50 GMT -5
Do you have lighter rollers to try?
Post by yar1993 on Oct 28, 2021 21:17:33 GMT -5
Do you have lighter rollers to try? i have the prima roller kit going to down jet first see if that makes a difference first.
Post by yar1993 on Oct 28, 2021 21:23:34 GMT -5
I also should probably look into a rpm gauge if y’all have any suggestions?
Post by Zino on Oct 29, 2021 8:29:39 GMT -5
