Post by pete130 on Jan 9, 2022 3:44:35 GMT -5
Gear box bearings are so much easier with the proper tool. 👍 Yes, I ended up buying a 6000kg press only a bench top one but made doing all my mains and gear.box so easy, and add a little heat they just about fall in lol
Post by pete130 on Jan 11, 2022 4:45:06 GMT -5
Looking great, I to started to put plastice back on, looks like a real bike again lol
messenger
Post by messenger on Jan 14, 2022 10:41:12 GMT -5
Couple of pictures of fitting the gearbox cover with the new input bearing. The input shaft fitted into the gearbox cover. Its a common misconception on the piaggio motors that you have to remove the rear wheel and remove the gearbox as a whole. But as can be seen here that isnt the case, you can simply take the gear box cover off and leave the secondary gears in place. And finally a picture of the completed Runner basking in the sun on the street.... it looks like a lovely sunny day, but this morning there was a hard frost on the ground and the temperature in the picture is hovering around 0 degrees centigrade. And theres a fire up video
Post by yambw’s on Jan 14, 2022 14:57:01 GMT -5
Lovely work mate! When’s the mot ?
messenger
Post by messenger on Jan 14, 2022 16:41:33 GMT -5
Lovely work mate! When’s the mot ? cheers... will probably hold off until the spring... or i might wake up one day before then and say sod it lets get an MOT
