Post by Scootrific on Jul 6, 2024 4:50:51 GMT -5
I thought I sorted out the oil pressure light issue on the dashboard, by adding some engine oil. I was so wrong. Today, when I started the car, the oil pressure light came on and slowly faded away again. Now I think, I might swap out the oil filter and do a oil change too. Maybe that will fix the problem. Still, the light does not turn on while driving.
Post by aeroxbud on Jul 6, 2024 14:47:56 GMT -5
Has it always been like this? If so perhaps the system needs to build pressure before the light goes fully out.
Post by Scootrific on Jul 8, 2024 11:38:22 GMT -5
Has it always been like this? If so perhaps the system needs to build pressure before the light goes fully out. Before, the light went away right after the engine was started. When the engine warms up, the light goes away slowly, within 15-25 sec now. When the engine is hot, while riving, then the light stays off.
Post by Scootrific on Jul 8, 2024 11:39:09 GMT -5
Today I made a Rocet Stove. It is 90% done ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) ![](https://i.postimg.cc/hGV5hJvX/DSC-3213.jpg)
Post by Scootrific on Jul 12, 2024 22:43:21 GMT -5
Yesterday, I changed my car´s oil and oil filter to see, if that fixes that oil pressure light issue on my car dashboard.
This is the 3rd video about the sound isolation of the car cabin:
Post by Scootrific on Jul 12, 2024 22:48:38 GMT -5
I also made video about the making of the "Rocket Stove" it is fast forward video, with music. I do not talk much in my videos. I got on fire 3 times, while building that stove. Atleast I was warm ![:D](//storage.proboards.com/forum/images/smiley/grin.png) lol I might find those clips from the footage and make some short videos ![:D](//storage.proboards.com/forum/images/smiley/grin.png) But That is the fast forward video of that build:
Post by aeroxbud on Jul 13, 2024 9:29:21 GMT -5
That's a lot of work involved in making that. We need to see it working. 🔥
Post by Scootrific on Jul 26, 2024 14:06:16 GMT -5
That's a lot of work involved in making that. We need to see it working. 🔥 I think that time will come. But my vacation is almost over.
Post by Scootrific on Jul 26, 2024 14:07:15 GMT -5
Yesterday and today, I worked on BBQ Grill. Made video too. This one in that video is second one, that I made.
Post by Scootrific on Jul 30, 2024 0:50:42 GMT -5
Post by Scootrific on Aug 20, 2024 6:09:17 GMT -5
My Attempt to swap the outer driveshaft end. Failed!
Post by Scootrific on Aug 27, 2024 9:22:11 GMT -5
Few days ago, I did try to swap the driveshaft end again, but with no luck. When I did close the garage door, I heard a big bang. I opened the garage door (it was heavier, then usual), turned on the lights and saw this (the door balance weight bar was broken from the old weld): ![](https://i.postimg.cc/GhGMzdc4/DSC-3325-2.jpg) Then I placed a round bar, to keep the door half open and fixed the door weight bar and added additional small bar for support. ![](https://i.postimg.cc/CL78wQ7v/DSC-3328.jpg) ![](https://i.postimg.cc/DwYbX4tL/DSC-3329.jpg) Yesterday morning I did weld on two round bars, to both door counter weight bars for more support.
Post by aeroxbud on Aug 27, 2024 14:24:32 GMT -5
That's putting up a fight. It's either easy, or a nightmare. No inbetween.
Post by Scootrific on Sept 6, 2024 16:51:24 GMT -5
That's putting up a fight. It's either easy, or a nightmare. No inbetween. That thing was quite heavy ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
Post by Scootrific on Sept 6, 2024 16:52:54 GMT -5
I have that kind of situation for a long time: Driver side front marker light works, and passenger side does not work. Back marker/running lights work. I changed the front passenger side marker light bulb, but it still do not work. Fuse is all fine and not broken. The old passenger side marker light bulb faded out slowly, when it stopped working. What could be the issue? Ground maybe? Maybe I could take ground from the driver side bulb and add it the passenger side? ![](https://i.postimg.cc/KjzbmJcm/DSC-3350.jpg) ![](https://i.postimg.cc/J02L0ZtZ/DSC-3351.jpg)
