Post by milly on Feb 12, 2024 14:04:19 GMT -5
Post by FrankenMech on Feb 12, 2024 14:12:23 GMT -5
You wish...
Post by jackrides on Feb 12, 2024 14:12:34 GMT -5
He has a Fine teacher. Electrical has its own learning process, as you know.
Post by milly on Feb 12, 2024 16:16:39 GMT -5
Most likely end up father mending the things till to achey to bend over. 🤪
Post by FrankenMech on Feb 12, 2024 19:32:43 GMT -5
Most likely end up father mending the things till to achey to bend over. 🤪 That seems to be the probable outcome.
Post by aeroxbud on Feb 13, 2024 4:48:02 GMT -5
Most likely end up father mending the things till to achey to bend over. 🤪 That seems to be the probable outcome. Or son wins the lottery.
Post by milly on Feb 13, 2024 6:13:04 GMT -5
Bike loaded in the lovely Welsh rain on way to deliver
Post by milly on Feb 13, 2024 11:49:43 GMT -5
Post by FrankenMech on Feb 13, 2024 13:49:25 GMT -5
My naps keep getting more frequent and longer... I seem to get out of bed only to eat and sh**.
Post by milly on Feb 19, 2024 10:35:20 GMT -5
Bugger well that idea of new tap didn't work. Back to the drawing board. Bodge back in place.
Post by FrankenMech on Feb 19, 2024 12:59:18 GMT -5
What is the ball bearing for?
Post by jackrides on Feb 19, 2024 15:27:17 GMT -5
Old K triples had a hinge in the middle, I guess the previous owner wanted the same handleing.
Post by aeroxbud on Feb 19, 2024 15:49:21 GMT -5
What is the ball bearing for? Looks factory to me. 🤔
Post by milly on Feb 19, 2024 17:05:50 GMT -5
The bearing and wheelnut and rubber block is just to space it out, just happened to be things to hand at the time laying about. Hence bodged till proper tap comes along 🙂
Post by FrankenMech on Feb 20, 2024 0:17:17 GMT -5
The bearing and wheelnut and rubber block is just to space it out, just happened to be things to hand at the time laying about. Hence bodged till proper tap comes along 🙂 Been there done that before. Why else would my name be FrankenMech. I used parts and pieces of machines laying about to make things. Not as much as I used to though, -just getting too old to even pick up parts, much less make anything. I should change my name to FrankenStupidOldMoron nowadays.
