Post by oldgeek on Jan 5, 2013 21:26:47 GMT -5
I did a small amount of matching the boost port on the cylinder (orange) and i am thinking about trimming the cylinder on the black marks to match it to the transfers a little better (red). Is this ok to do?
Post by 190mech on Jan 6, 2013 5:13:46 GMT -5
Yes,trim them,be sure to round the cylinder base where the mixture flows into the transfer tunnels.. :thumb:
Post by oldgeek on Jan 6, 2013 7:47:32 GMT -5
Are you talking about the area I have marked in blue? BTW, I will be rolling past you Monday on I-20. I have to take my daughter back up to Spartanburg for college.
Post by 90GTVert on Jan 6, 2013 9:17:25 GMT -5
I try to round or smooth all of the edges down there a bit. Not sure if it's really beneficial in all spots.
Post by 190mech on Jan 6, 2013 18:55:23 GMT -5
Good pic Brent!Thats what i was talking about!! :cheers:
Post by oldgeek on Jan 6, 2013 21:01:19 GMT -5
Thats what I was looking for thanks! Mine will be a little different cause its thin cast iron. The one in your picture is aluminum I believe? I also need to open up the boost port on the cylinder just a bit.
Post by 90GTVert on Jan 6, 2013 21:43:22 GMT -5
It's a stock 40mm iron cylinder in the pic.
Post by martyd on Jan 6, 2013 22:12:34 GMT -5
So is porting a have to thing or is it just a way to try and squeeze every bit of hp out of the motor ? I have read alot about this but am still confused
Post by 190mech on Jan 7, 2013 5:36:38 GMT -5
Marty, You can just bolt on a cylinder and ride! If you want the engine to run as good as the designers made it before the manufacturers and bean counters started cutting corners,porting is needed.. =John=
Post by 90GTVert on Jan 7, 2013 5:47:52 GMT -5
The main things that you should check if you just wanna bolt on a cylinder kit are the port chamfers. You don't even have to do that, but it's best to remove rough edges from the ports where they enter the bore.
Post by oldgeek on Jan 7, 2013 6:55:41 GMT -5
It's a stock 40mm iron cylinder in the pic. Oh, ok. The thickness was throwing me off. I am trying to figure out how much can i take off of the boost port "tabs" on the cylinder without worrying that they are too thin. In your picture It looks like you were able to remove quite a bit, but mine are much thinner. I did see in project90 I think, where you ended up with a very small tab after you finished porting. I guess its about time to finish screwing with the cases, install the crank and see how the piston looks in the bore.
Post by 90GTVert on Jan 7, 2013 7:51:27 GMT -5
I really don't know the limits. Anything that will see a lot of miles I tend to be much more conservative.
Post by oldgeek on Jan 7, 2013 9:54:14 GMT -5
I really don't know the limits. Anything that will see a lot of miles I tend to be much more conservative. Very good point, Thanks for reminding me. I do want this build to last a long time. I tend to forget the end goal along the way!
Post by oldgeek on Jan 8, 2013 19:56:44 GMT -5
Ok I have a couple questions to ask. Has anyone used the replacement for three bond 1194, since they no longer make it? Should I just use Permatex ultra grey? The replacement is 1184. I ordered 1194, but they sent me this. I have crank bearings from NACHI and TPI. The TPIs came labeled HOCA. Does anyone know which are better? And finally what torque values do I use for the crankcase halves, I don't recall seeing that info anywhere.
Post by 90GTVert on Jan 8, 2013 23:48:31 GMT -5
I use a 1/4" ratchet with the 8mm hex and just get the case bolts snug. Not sure on a tq figure.
From what I read, the 1184 sounds fine.
