Post by 2TDave on Mar 10, 2015 6:22:07 GMT -5
I agree that's a bit tight. S6 recommends .6 +/-.1 on the MKII aluminum cylinders. I'd think it'd be higher on an iron kit.
Post by oldgeek on Mar 10, 2015 6:46:59 GMT -5
I think when I get time to tweak the carb, and CVT it should top the 60mph mark. I am currently @ about 11:1 final gears, what are my gearing options for this long case clone? Ya gotta remember that I am a big guy almost 300lbs. A lighter person would already easily be over 60mph. The last 130lb guy that rode it before the latest mods dont really want to ride it again! Sent from my SGH-T999 using proboards
Post by Lucass2T on Mar 10, 2015 9:10:39 GMT -5
How much belt travel do you have left on the front side? Is there room for a longer belt? About those gearing options i can't help you. I know that there are a million options for the genuine minarellis...the clones i don't know.
Post by 2TDave on Mar 10, 2015 11:40:41 GMT -5
Primary Malossi 14/42, S6 15/50. Secondary S6 14/52.
Post by oldgeek on Mar 10, 2015 12:57:48 GMT -5
How much belt travel do you have left on the front side? Is there room for a longer belt? About those gearing options i can't help you. I know that there are a million options for the genuine minarellis...the clones i don't know. I have not even started tuning the CVT yet. I know for sure I need some spacers to get the belt higher in the rear pulley, but beyond that I have no idea. I hope to have some time to work on that this week.
Post by oldgeek on Mar 10, 2015 13:06:58 GMT -5
Primary Malossi 14/42, S6 15/50. Secondary S6 14/52. I had a taller set of gears in there but the input shaft went bad last year so I traded them out with another set. Can you tell me which ones will get me just a bit better than 11:1? I am clueless about gear ratios.
Post by 90GTVert on Mar 10, 2015 13:29:40 GMT -5
What are the current tooth counts? I'm only used to ~10:1 & ~13.5:1 gears in stock long cases.
Post by 2strokd on Mar 10, 2015 13:47:25 GMT -5
What are the current tooth counts? I'm only used to ~10:1 & ~13.5:1 gears in stock long cases. You are probably thinking more on the lines of longcase gears, this is a shorty if i remember right?
Post by oldgeek on Mar 10, 2015 17:41:56 GMT -5
What are the current tooth counts? I'm only used to ~10:1 & ~13.5:1 gears in stock long cases. 1 turn of the rear wheel = 11 turns of the clutch bell. I will have to count the teeth sometime, but they are likely 13.5:1
Post by oldgeek on Mar 10, 2015 17:43:20 GMT -5
What are the current tooth counts? I'm only used to ~10:1 & ~13.5:1 gears in stock long cases. You are probably thinking more on the lines of longcase gears, this is a shorty if i remember right? This is my longcase 70cc Eurostrada. You are thinking of my other project, 99cc Zip shortcase.
Post by 2TDave on Mar 10, 2015 17:47:01 GMT -5
My Eurostrada RX8 was 10.13:1. I've got stock tooth counts if you need them.
Post by oldgeek on Mar 10, 2015 18:39:21 GMT -5
When I pulled the CVT apart earlier, I could see the belt was not near full travel on the variator. I was already using the heaviest weights I had, and who knows when my RP order with heavier weights will arrive. I decided to try to make some of the weights I have heavier by cutting some 3/8 copper pipe slightly smaller than the width of the rollers, and then I flattened the copper pipe just a bit to make a tight press fit inside the rollers. I put the much heavier rollers in the variator, and changed the main jet in the carb to a 102. The test ride was short, I could not get it to rev enough to hit the pipe using the heavier weights. The tach said RPM's were around 6500. I may go back over tho the warehouse, and try a mix of the heavy rollers, and some lighter ones.
I got to thinking, and am worried the copper pipe could be thrown out of the rollers by the force of the variator spinning. The copper pipes are in there very snug, but it is still a press fit. I guess I could use some JB weld to fill/add some weight to the rollers, but it takes a day for that stuff to cure.
Post by 90GTVert on Mar 10, 2015 21:57:49 GMT -5
The 10.13:1 gears should be : 10.13:1 (Primary 16/49 [3.06], Secondary 13/43 [3.31])
If you weren't real precise you may want to double check your tire to bell turns again. All we seem to hear about in the long case clones are the 13.5 and 10 gears.
Post by oldgeek on Mar 11, 2015 3:51:12 GMT -5
The 10.13:1 gears should be : 10.13:1 (Primary 16/49 [3.06], Secondary 13/43 [3.31]) If you weren't real precise you may want to double check your tire to bell turns again. All we seem to hear about in the long case clones are the 13.5 and 10 gears. It has been a while since I checked, so I will check again. Possibly I am confused, again, and I am thinking about the shortcase gears? LoL!
Post by oldgeek on Mar 11, 2015 10:45:52 GMT -5
Dangit, to sick to work, and to sick to work/ride the scoot. And the weather is beautiful finally, and the spring breakers are here. But its bedtime for me.
