Post by 90GTVert on May 6, 2010 6:05:11 GMT -5
jimh
Post by jimh on May 6, 2010 14:54:18 GMT -5
Sliders for my application are 15/12's, rollers too...getting there!
Post by 90GTVert on May 6, 2010 15:23:33 GMT -5
jimh
Post by jimh on May 6, 2010 15:29:56 GMT -5
Thanks Brent, that's a 5 buck save...put in in my favorites.
Post by redorchestra on May 7, 2010 16:13:00 GMT -5
I think our scoots have a similar top speed right now. I'm over 70km/h(fastest mark on speedo) but have not done a gps run yet.
What size belt did you get from Monster, and what are all the mods you've done so far. I know belt, rollers, and pipe. I still need a pipe.
jimh
Post by jimh on May 7, 2010 17:38:51 GMT -5
Rejetted the carburetor #60 stock to an #85, main. Gee, wonder what kind of performance I'd get with a larger carb; am currently running a 14.5 mm Mikuni, fair on gas at the moment but with the wind the last few days, have been emptying the tank super quick. Belt size...I'll get back with you on that, it's a Gates powerlink.
jimh
Post by jimh on May 7, 2010 17:41:10 GMT -5
Red, it's 669-18-30. Fingers crossed it's the proper size
Post by redorchestra on May 7, 2010 22:39:53 GMT -5
thats what mine takes too, but I have a 680x18 on it now. Higher top speed but I know the belt is loose at idle and lower rpms
jimh
Post by jimh on May 8, 2010 20:43:57 GMT -5
Does it give any indication that it is slipping or doing any shuddering at low speed?
Post by redorchestra on May 9, 2010 17:33:53 GMT -5
oh yeah, it shutters and stutters and the rpms go way up before it locks and goes. But I went out for a ride yesterday and buried the needle at least 10 km/h past max on the dial (i'd say 80km). I'll probably go back to a 669x18x30 like you, unless i can find a solution like an oversize vari, or tighter contra spring. The belt I realized is another coded belt, not sized. maybe I can find a vari from the scooter it was meant for.
I just don't think, i can get anymore speed out of the variator gearing. It will need more rpms or a final gear to get more with a regular sized belt. The 680 gives another 5-10km/h with just a little loss at the low end.
Right now I am matching speed with the delivery drivers on their geared 110cc cub clones. I think with a variator solution and a pipe I'll be able to beat them. Except... I won't run red lights or split lanes like they do, so I'll never really be able to beat them.
Post by redorchestra on May 9, 2010 17:44:13 GMT -5
I think what I really need is slightly larger clutch plates (Is that what they are called). the belt pulley on the clutch side. Are they standard sized?
jimh
Post by jimh on May 10, 2010 22:19:45 GMT -5
I really don't know but I'll begin researching and asking Q's.
Post by 2strokd on May 11, 2010 9:06:59 GMT -5
I think your speaking of the torque driver.?. If so, bigger better ones are out there but if you replace that you should replace the vari with a bigger one also or you may risk damage if the belt runs off the vari. I believe the best option is an over-range kit. They are pricey but man! The results are there! I saw em with my own two and a half eyeballs! Edit: heres one www.sip-scootershop.com/EN/Products/M6111062/Variator+Over+Range+MALOSSI.aspx
jimh
Post by jimh on May 11, 2010 19:35:55 GMT -5
You mean you saw one working/installed? I heard someone say something about an overrange kit but wasn't paying attention.
Post by redorchestra on May 12, 2010 5:56:52 GMT -5
Was it the pink scoooter at TAG?
