Post by 190mech on May 11, 2010 3:38:24 GMT -5
I did a web search last night about case(carter) tuning and found quite a few tuners did a trench cut from the reed area to the main transfer entry,guess the theory is when the reeds open the second time during pipe suction,the mixture flows smoothly to the main transfers..Here is a pic I scrounged to illustrate the mod; I may use this trick,what do ya'll think?
Post by 90GTVert on May 11, 2010 6:16:29 GMT -5
Interesting. I'm not quite sure what to think of that. It sounds like a good idea, but I dunno how it will actually work. If it's being done by sources that you'd trust, I say go for it.
Post by 190mech on May 11, 2010 7:42:12 GMT -5
Case tuning seems to be as secretive as pipe building,dont know why,but I'll keep digging and post what I find..
Post by 2strokd on May 11, 2010 8:32:28 GMT -5
I have read about that also...They said they were strong when finished . Makes sense to me, ide say try it, if it turns out to be bad it can be filled back in later. I know the motor would need torn back down tho. I gotta extra case for ya if something really bad happens :thumb: . What crank did you get again? The splines the same?
Post by stepthrutuner on May 11, 2010 8:33:18 GMT -5
My theory in performance tuning of late is.... go big, straight and smooth on the bottom end and transfers but keep the pulse energy to the pipe high and let the pipe do all the work.
Post by 190mech on May 11, 2010 9:18:24 GMT -5
Any links or articles would be appreciated!!!
Post by 2strokd on May 11, 2010 9:28:20 GMT -5
Post by 2strokd on May 11, 2010 9:53:09 GMT -5
Post by stepthrutuner on May 11, 2010 10:48:07 GMT -5
Post by 2strokd on May 11, 2010 11:03:16 GMT -5
:welcome: Thanks for the help :rockon:
Post by 190mech on May 11, 2010 11:23:33 GMT -5
WOW! Thanks guys,looks like I've got a lot of reading to do..Wax looks like his setup should flow well,will study all carefully tonight. THANKS!!!!!!!!
Post by 90GTVert on May 14, 2010 5:56:13 GMT -5
Tip... If you ever need extra 54mm head/base gaskets, email autotech355@gmail.com . He just charged me $1 per set and I had been paying $20 per set from the ATV sites.
Post by 190mech on May 14, 2010 14:13:13 GMT -5
Wow!Carlos has some good stuff at better prices,and he gives a better price if you contact him directly as Brent did.Still waiting for my stroker crank,hope its here tomorrow...Will post pics.
Post by 2strokd on May 14, 2010 15:45:58 GMT -5
:popcorn:
Post by 190mech on May 15, 2010 19:29:46 GMT -5
Beadblasted and epoxied the outer cases today so when I begin to cut the transfer and 'trench' port there is no worry about going through to the other side.No new crankshaft yet,been looking for some economical up gears for the tranny too..
