Post by 190mech on May 8, 2010 19:11:21 GMT -5
I finally decided to start a project I've wanted to do for a while. A 50cc scoot with a 100cc engine,geared so it will cruise at 60 without turning a million RPM.I ordered a NCY 54mm cylinder kit for a 90cc engine,have a 45mm stroker crank on the way. Cases must be cut to fit both the larger cylinder and crankshaft. Got the engine off and mostly apart; Here is the 50cc,70cc,and 54mm(103cc with stroker crank)cylinders; This is how much metal must be removed for the cylinder to fit the case; Will post more when my work schedule allows me to tinker,,,
Post by stepthrutuner on May 8, 2010 19:39:57 GMT -5
Cool. I think you should call this Project Echo Chamber. ;D
Post by 190mech on May 8, 2010 20:02:51 GMT -5
Thanks Reg!I am planning on a new quiet pipe for it,want to ride un-noticed by all the anti scoot types
Post by stepthrutuner on May 8, 2010 20:51:40 GMT -5
Hello Hello Hello. This is my new Big Big Big Bore Bore Bore.
jimh
Post by jimh on May 8, 2010 21:11:49 GMT -5
Dang, that's a big pot!
Post by 90GTVert on May 8, 2010 22:17:16 GMT -5
I'm very glad to see you getting this project underway. I have no doubt that it will be a beast with you building it.
Post by 190mech on May 9, 2010 5:25:34 GMT -5
Thanks!I ordered the cylinder studs and shroud last night,hope to have some time today to split the crankcase(why do they call them 'carters'?)and figure out a fixture to mount it in the milling machine..
Post by 2strokd on May 9, 2010 7:32:36 GMT -5
I dunno, but im looking forward to seeing this puppy run ;D! Gonna be interesting to say the least
Post by 190mech on May 9, 2010 18:45:01 GMT -5
Got some time to 'make chips' today.Setup the cases in the mill to cut the cylinder mouth; After many chips,here is what it looks like; Here is the cylinder test fit,Whew,it fit! Started roughing out the transfer tunnels; Here is the cylinder in the case,ya'll think that web under the boost port needs to be cut straight down?
Post by stepthrutuner on May 9, 2010 19:01:17 GMT -5
Hard to say. You say you're building a mild motor. It would very slightly decrease primary compression wouldn't it?
Post by drawkward on May 9, 2010 19:36:36 GMT -5
Seems a little sketchy to me. How thin of a wall would you be talking here at the bolt hole?
Post by 190mech on May 9, 2010 20:16:48 GMT -5
I have a 'stuffer' crank ordered,so that should keep the primary compression up.. Might cut a little more on that case channel,but worry about the bolt hole and case support there.Ive also seen where guys are cutting a 'scallop' out of the rear cylinder skirt to aid in boost flow.Like this; i34.photobucket.com/albums/d101/MomoMexicano/More%20Taz/CaseTuning17.jpgThe 50cc case appears to be restrictive in these areas for proper cylinder filling and I think some time spent here will make a stronger running engine..
Post by 90GTVert on May 9, 2010 20:48:38 GMT -5
:drool:
You made that look easy.
I agree that you are getting a little too close for comfort to that case bolt hole if you cut it straight. I'd definitely look to alternative methods for increasing flow.
Post by 2strokd on May 9, 2010 23:32:33 GMT -5
When this thing done its gonna be like , and everybody that want to race is gonna be like . And John will be . I think this build is And a . . Should be fine to cut a U in the skirt i would think? Now im gonna sit back and let the master work
jimh
Post by jimh on May 10, 2010 20:06:21 GMT -5
Hahahaha...............this is going to be great.
