Post by 2strokd on Mar 18, 2012 21:55:43 GMT -5
I will never seize to be amazed at the stuff you come up with! Think simple but effective, work smart and hard.. Cool stuff man! Good work ! Wish you could get that puppy up here for TnG
Post by scoottrash1990 on Sept 19, 2013 5:42:26 GMT -5
where did you get the nyc 54mm cylinder? what stroker crank are you running....im looking to do a 103 stroker build on my vento.....the only 54mm cylinder I can find is the hoca.....thanks
Post by 190mech on Sept 19, 2013 9:11:32 GMT -5
I got it off an ebay store,the Hoca is as good quality as the NCY.45mm stroke crank came from autotech355..
Post by scoottrash1990 on Sept 19, 2013 14:52:24 GMT -5
i found the crank....it come with bearings and seals....did you use the bearings that come with it? are they any good? thanks....
Post by 190mech on Sept 19, 2013 19:44:10 GMT -5
Yep,I used them and all is still running well!
Post by scoottrash1990 on Sept 19, 2013 19:59:54 GMT -5
cool....what kind of epoxy did you use when you did the trench porting? sorry for all the questions but your build is really close to what i want to do.... thanks again
Post by kevin55950 on Sept 19, 2013 20:35:04 GMT -5
Devcon F aluminum putty (I talked to him before doing mine, and this stuff is great )
Post by scoottrash1990 on Sept 19, 2013 20:50:01 GMT -5
never heard of it....i will have to look around....thanks kevin...
