Seems like forever to me (5 days lol) since I updated the thread. I wanted to get a few things together and get a vid done so all the stuff is here at once.
You can check out this update in video form and watch the runs in HD...
www.youtube.com/watch?v=K5j8gHg5kMcSince last time, I started by seeing what I could get out of the carburetor and CVT with just basic tuning. I made a bunch of WOT runs about 2 miles each way and wrote down max speed each way, RPM at those speeds, air'fuel ratio, and max CHT. A simple trial and error method that anyone can do, really only needing a speedometer and a place to run. The more gauges the better though.
These are the results of the test passes.
Avg Speed is average of top speed each way. Avg RPM is average of RPM at top speed each way.
Main Jet
| Max CHT
| Avg Speed
| Avg RPM
| Air/Fuel Ratio
72 | 361°F | 33MPH
| 6,820
| 13.5 - 15
75 | 352°F
| 36.45MPH
| 7,265
| 11.5 - 13 |
78 | 341°F
| 34MPH
| 6,995
| 10 - 11.5 |
79 | 338°F | 33.6MPH
| 6,965
| 10 - 11.5 |
80 | 337°F | 33.35MPH
| 6,950
| 10 - 11.5
82 | 331°F | 32.85MPH
| 6,865
| 10 - 11
85 | 292°F | 28.5MPH
| 6,675
| 10
Even though the wideband had been showing rich readings, I wasn't sure it was accurate. I actually did the runs from 75-82 another time just to be sure results were the same. 85 was very obviously too rich. It felt dead compared to the rest and the part throttle sputter was terrible. I went with the 75 main when I got similar results on a second set of runs.
Here's what the spark plug looked like after 150 miles of running rich at 10-11.5:1 air/fuel ratios most of the time (pre-tuning).
I re-adjusted the idle mixture screw. Then I shimmed the needle up to richen it. I had been pretty certain the sputter that many say is a lean stock issue was really a rich condition (sputters tend to be and the wideband hits 10:1 when it happens), but I just had to be certain. Sure enough, it got worse. I ordered a needle from Parts For Scooters for $3. It may have worked, but I didn't like how thin it was where it passes through the slide and how much it could move. Not really sure it matters, since the needle shouldn't pull all the way out anyway.
I left the stock needle and called the carb done so I could move on to CVT tuning. I started with finding the Dr Pulley sliders that would work best. I've compared rollers and sliders in the past, and I've always liked sliders. Might as well cut to the chase. I did take a run with 5g rollers first, to see what the difference would be in 5g rollers vs sliders. That surprised me. The sliders raised RPM substantially vs rollers of the same weight. I've tried them side by side in my Minarelli engines multiple times and they always produce similar RPM. Not the case for the GY6 50 variator. Here's a look at speed and RPM with various weights.
Avg RPM is average of RPM at max speed each way. Avg Speed is average of top speed each way.
Weight | Max RPM
| Avg RPM
| Avg Speed
5g Rollers (Stock)
| 7,650
| 7,000
| 32.75MPH
5g Sliders
| 8,220
| 7,690
| 34.45MPH
4.75g Sliders
| 8,380
| 7,800
| 35.45MPH
4.5g Sliders
| 8,450
| 7,910
| 34.85MPH
4.25g Sliders
| 8,670
| 8,110
| 34.8MPH
4.75g sliders gave the best all around performance for me. 4.5g sliders were a little quicker accelerating, but I think revs would be a little too high for best cruising/speed results. The 5g sliders would probably be a better choice if the scooter were a little faster, but the TaoTao is lacking the power to pull me very fast. I went with the 4.75g sliders.
I was surprised to see the stock rollers looking as good as they did when removed. I started noticing flat spots after the first ride, but it seems they've worn in pretty round.
The stock bushings were getting a little worn, so I replaced those with Dr Pulley bushings as well.
Then I worked on the clutch springs. I found that 1,500RPM springs gave me the latest engagement before the rest of the CVT started shifting.
I went for a 34.9 mile ride and speeds increased just a little. There was a 1-2MPH gain in average WOT cruise speed, now 33-34MPH @ around 7,8-7,900RPM on average. Max speed went up nearly 1MPH to 38 @ 8,100RPM. I can easily go faster on slight declines or with a little tailwind while just cruising than I can tucking down in "honest" conditions. CHT and oil temps didn't show any big changes vs stock. Max CHT was 378F. The highest oil temp I recall seeing was about 230F.
The big improvements were in acceleration and gas mileage. Gas mileage went up to 95MPG vs just under 82MPG with the stock setup. Not only is the main jet smaller, but with the improved CVT tune I could stay at lower throttle in town. I didn't need to pin it every time I tried to move. 0-30MPH average time was 18.71 seconds vs the stock average of 26.88 seconds. A huge improvement.
Overall, I'd say the basic tuning was a big success. I already had the stuff, but a jet kit is about $15 from Parts For Scooters , a set or two of sliders at $20 each from there or elsewhere, and the Hoca clutch springs are about $10 a set. That's $45 to maybe $100 depending just how wide of a selection of stuff you want. Sounds kinda pricey, but it feels amazing vs stock and additional tuning supplies usually come in handy (at least for me).
The next thing I tried was removing the restrictions from the stock airbox. I kinda hate calling them restrictors in one sense, because with these scooters we hear "restrictors" and automatically think something is holding us back. Removal is very easy. Take the screws out and pop the cover off of the airbox. You'll find this under the lid.
It can be pulled up and out with ease, leaving a much larger inlet.
There is still some restriction though. There's a cap on the end that can be removed, or the whole inelt hose can be unclamped. I opted to remove the entire hose.
Reinstall the lid and that part's finished. Once I started the scooter, it wouldn't go more than a few feet WOT before the wideband pegged at 16.0 (leanest) and the engine surged. I ended up going from a 75 main jet to a 90 main jet, a 20% increase, to get it running right.
I went for a 31.9 mile ride that night to try it out. I really couldn't feel a difference, but I was hoping maybe speed would increase or something. WOT cruise speed/RPM and top speed/RPM stayed basically the same as before. 38.2MPH max tucked, .2MPH faster than before. Tucked speeds are kinda odd now though. I try to keep them fair, but power is so low on the stock scoot that anything being different can change speeds easily. CHT was a little cooler at 267F. I think that may be more from the few degree cooler night vs other runs. Oil temp was again around 230F. Fuel economy dropped a little, to 91.6MPG. Not sure that tells anything either, because I had a headwind to fight for a bit and it's such a small percentage difference that minor things could have changed that.
0-30MPH acceleration averaged out at 18.58 seconds. It was 18.71 previously.
My opinion is that removing the restrictions essentially did nothing other than require a larger main jet. Even the part throttle richness was still intact. I did opt to leave the restrictions out though. Mostly for later on if airflow becomes more important.
Last but not least, I swapped on a Keihin PD19J carburetor in place of the stocker (also labeled PD19J, but definitely not a Keihin). It's not hard to see casting and quality differences in the two carbs.
The difference that most interested me at that point was the adjustable needle.
I tuned the Keihin and it liked the same 90 main jet that the stock carb used. It had a 33 pilot and I ended up with the mixture screw about 1 turn out. I set the needle in the leanest position to finally see a change in part throttle mixture and get rid of most sputtering. Even on the leanest setting, air/fuel ratios at part throttle were most commonly 11-13:1.
The Keihin's accelerator pump seems to deliver more fuel than stock. If I pump the throttle it will peg the wideband at 10:1 and with a few more pumps the engine may die.
I went for a 32.6 mile ride with the new carb and again got about the same speed, RPM, CHT, and oil temps as before. The two big changes were 0-30MPH acceleration and fuel economy. Mileage increased to 98.2MPG, likely due to better part throttle settings. 0-30MPH acceleration was almost 7 tenths of a second quicker. It didn't seem as if the scooter made more power, but rather RPM picked up quicker off the line without the excess fuel causing a sputter and stumble.
I was pleased with the carb, but I think similar results could be had with simply an adjustable needle in a stock un-sealed carb. That's not to say I think the stock carb is the same quality, but it could likely work the same at least for a while. I'm sticking with the Keihin on Project TaoTao.
After seeing 98MPG, and being so close, I just had to hit 100MPG. I don't recall getting 100MPG on anything. I went out another night and rode using part throttle to cruise 25-30MPH and tried to be gentle with the throttle. I avoided WOT for the most part, other than for safety concerns with faster moving traffic. 43.9 miles of riding later, I filled up with 0.399 gallons of gas which made 110MPG! I don't really plan to ride that way, but at least I finally got into 3 digit mileage at least once.
