Post by nelson on Nov 23, 2013 12:35:10 GMT -5
m.ebay.com/itm/141118796363?nav=SEARCH&sbk=1 Will this here crank work?
Post by ryan on Nov 23, 2013 12:44:25 GMT -5
yes it would. hes one of my friends out of Georgia gives alot of good deals
Post by nelson on Nov 23, 2013 12:49:26 GMT -5
Post by nelson on Nov 23, 2013 12:50:09 GMT -5
Thanks I may get it. Waiting for a paypal refund
Post by nelson on Nov 23, 2013 19:32:11 GMT -5
i have a engine question. On the flywheel side is the oil pump. I am getting rid of it. There is a circlip and then a round plastic peice that has a steel rod that slides through the crank that holds it in place.under the plastic (looks like a small doughnut) is another circlip. If I am not going to use oil injection and longer do I need to put that plastic doughnut and circlips back? Or is the only thing I need on the flywheel side is the key, flywheel and fan?
Post by 2strokd on Nov 23, 2013 19:54:36 GMT -5
You can leave it out yes
Post by ryan on Nov 23, 2013 22:00:40 GMT -5
thats the biggest ripp off for 60 bucks lol,
Post by nelson on Nov 24, 2013 16:14:12 GMT -5
What reeds should I use? Or should I get a different reed block? I am splitting the case as I won a doppler endurance crank for 100$. So if I had to do a bit of removal from the case so a different block will fit I can. Or just get some fiber reed as with stock boot?
Post by nelson on Nov 24, 2013 16:45:22 GMT -5
i won this crank, is it a good one? i think so but would like another opinion. I also got the case split yesterday and the old bearing out. Is there any case mods to perform before putting new crank and bearings in? Like does the intake need modified if i am going to use a V3 reed block? thanks guys
Post by nelson on Nov 25, 2013 17:50:54 GMT -5
Post by kevin55950 on Nov 25, 2013 18:08:02 GMT -5
Dell'Orto are good carbs 17.5 will take less fuel than 19mm, it's enough for a street 70cc set-up.
Post by ryan on Nov 25, 2013 18:12:35 GMT -5
id go with a 19mm minimum or up to 21mm for 70cc.
Post by moofus02 on Nov 25, 2013 18:58:36 GMT -5
Post by nelson on Nov 25, 2013 19:28:20 GMT -5
Cool, i think I am going to try a 21mm. What about reeds? Use stock block with new petals?
Post by 90GTVert on Nov 25, 2013 19:45:02 GMT -5
