Post by ryan on Nov 20, 2013 22:26:47 GMT -5
they had 10mm i bought 2 last month?
Post by kevin55950 on Nov 21, 2013 12:12:23 GMT -5
There are adapters to fit a 12mm crank with a 10mm kit but they are far from being reliable as the 12-to-12mm or 10-to-10mm bearings.
Post by nelson on Nov 21, 2013 13:10:46 GMT -5
There are adapters to fit a 12mm crank with a 10mm kit but they are far from being reliable as the 12-to-12mm or 10-to-10mm bearings. hey man, havent got the crank yet but i did buy Handlebar stem BCD CNC Short Neck 130mm - Color : matt blue from your site. Hope it fits my 92 jog!
Post by kevin55950 on Nov 21, 2013 19:51:51 GMT -5
It does fit: I have the RX on my jog, it fitted Zuma and jog forks You'll see, it looks mad with this and front fairing
Post by nelson on Nov 22, 2013 8:35:14 GMT -5
nice! i had to have something as the previous owner chopped some stuff off and had a neck from a cheap bicycle with one bolt that holds the handlebars. It had that little wedge that a long bolt runs through to keep bars from moving. I was kinda worried about that. now no worries
Post by nelson on Nov 22, 2013 14:26:31 GMT -5
Post by nelson on Nov 22, 2013 14:29:52 GMT -5
dude i just got a message saying the only one they have available is the brushed aluminum(when i ordered they said they had blue). I had a friend use his paypal so kinda makes me stuck. You guys should keep better track of your inventory.I bought this from them because you said they were good. NOw im just stuck
Post by nelson on Nov 22, 2013 15:48:48 GMT -5
Post by 90GTVert on Nov 22, 2013 15:50:17 GMT -5
Should fit, but that's not a great choice IMO unless you are going big with the carb. The reed block doesn't always fit without filing screws down and the intake is huge and some have even had it leak at the fittings. IMO save it or buy some tools or something like that with the Amazon credit rather than buying parts you don't really want just because you have it.
Post by 2strokd on Nov 22, 2013 15:54:13 GMT -5
Yep, i agree. I have that intake and its so big its performs worse than stock on anything smaller than a 90cc IMO. The fittings leaked, used epoxy to seal them.
Post by nelson on Nov 22, 2013 15:54:20 GMT -5
new pipe is here..yeaaa....but wait it has dents in it j/k
Post by nelson on Nov 22, 2013 15:56:36 GMT -5
thanks guys. i plan on running a 17mm carb. will probably end up just using stock reed block and replacing petals.
Post by ryan on Nov 23, 2013 11:21:56 GMT -5
use a 19-21mm carb. stock was around 19 for the minarellis nowadays
Post by nelson on Nov 23, 2013 12:26:58 GMT -5
Stock 92 is really small. Like 14mm. I assume it is because the orig motor was a low rever. Will 19 mm fit stock intake?
Post by ryan on Nov 23, 2013 12:30:55 GMT -5
yeah it should. look up 1e40qmb or mianrelli on ebay and they have alot of stock carbs etc for like 20 bucks
