Post by 2TDave on Jan 16, 2014 16:13:16 GMT -5
Cvt parts arrived! Ran the vari with the 4.5 and 5 gram rollers and stock springs. Both had better and smoother acceleration. The 4.5 have me 55mph @ 10,100rpm while the 5 have me 52 @ 9,500 rpm. Change to med clutch springs and the hard torque spring. 4.5 grams 52 mph @10,300 and 5.5 gram at 9800. It's windy and gusty today and cold(59) brrr. So it's hard to judge speed results because of wind. I have about a half inch left on the variator that isn't being used. Any suggestions. Attachments:
Post by 90GTVert on Jan 16, 2014 16:26:03 GMT -5
I'd go back to the medium spring or stock and then dial it in. Sounds like stock should work. One reason I do like using aftermarket springs though is that you can buy the same spring again. Stock varies sometimes, but if you use a Stage 6 medium or Hoca 1000 or whatever, you can buy that same spring again. Could be useful later. Usually I go with the softest spring that gives me choices with weight. I don't want to use a stock spring if I have to use my lightest weights to get in the ballpark. I'd rather use a little stiffer spring and have weights lighter and heavier for future adjustments if needed. Always easier to swap the rollers later than springs. I only go with really stiuff springs if the belt slips. Makes it easier to service the CVT without a really stiff contra.
Post by 2TDave on Jan 16, 2014 16:42:17 GMT -5
I thought the vari was coming with a medium so I ordered a heavy. Well the vari came with a heavy. Now I have two.
Post by 2TDave on Jan 16, 2014 17:51:18 GMT -5
Went back to stock torque spring. 5.5 gr 53mph @ 9800rpm. Mix of 5 and 4.5 gr 54mph @ 10k rpm. Quick to about 45 then slowly climbs. Hoping the c16 will get me a lot faster quicker. Still stock pipe.
Post by 90GTVert on Jan 16, 2014 18:45:57 GMT -5
Didn't even realize it was still the stock pipe. It should really come alive with the C16.
Post by ryan on Jan 16, 2014 19:05:42 GMT -5
id expect bigger main when c16 comes and maybe needle adjustment along with roller and spring adjustments for full advantages being taken
Post by 2TDave on Jan 16, 2014 19:39:31 GMT -5
I hoping so Brent. I figured I'd be retuning everything but figured I'd be closer by starting now. I have a 95 main in now and it's a bit rich. I have plenty of larger jets. The heaviest rollers I have are 5.5 grams. I have the s6 strong torque spring and heavy clutch springs. Do you think I'll need a 1k and 1.5k torque spring and heavier rollers?
Post by ryan on Jan 16, 2014 20:39:58 GMT -5
what weights you use? 15x12 and 16x13
Post by 2TDave on Jan 16, 2014 21:11:11 GMT -5
16x13. S6 sport pro vari. I have 4,4.5,5, and 5.5.
Post by ryan on Jan 16, 2014 21:42:01 GMT -5
ive got some 6-8s i believe and you get my messages?
Post by 2TDave on Jan 16, 2014 22:03:21 GMT -5
No messages yet.
Post by ryan on Jan 16, 2014 23:27:35 GMT -5
ill resend them?
Post by ryan on Jan 16, 2014 23:28:51 GMT -5
oh sorry another member has a similar name lol my bad
Post by 2TDave on Jan 17, 2014 6:43:27 GMT -5
I might have chosen something different had I known. People probably wondering why he's lost his mind reading my posts. Lol
Post by 2TDave on Jan 17, 2014 16:23:41 GMT -5
More cvt tuning. Stiff clutch springs, stock torque spring and 5.5 gram rollers. Great low end and pulled strong to 45. Kept going up a little slower to a max 56 mph wot. Still stock pipe. Only 3mm of the line I drew on the variator face left with 1mm spacer in. Attachments:
