Post by 2TDave on Apr 27, 2015 5:45:03 GMT -5
Thanks OG. I got the idea for tapping the inside from another member here. Much easier than retapping the existing threads. Ace is the place around here for fittings and connectors.
Post by niz76 on Apr 27, 2015 23:30:41 GMT -5
Nice clean solution. Isn't about time u posted another pic of this scoot? Hehe I just want to see it again
Post by 2TDave on Apr 28, 2015 5:33:41 GMT -5
I can do that.
Post by 2TDave on Apr 28, 2015 5:35:32 GMT -5
Post by moofus02 on Apr 28, 2015 7:18:08 GMT -5
What you running for a rear shock?
Post by 2TDave on Apr 28, 2015 7:29:12 GMT -5
It's one I got from the same aliexpress seller I got the front suspension and brakes from. I don't have a shock pump so I have not played with it. It's pretty stiff right now.
Post by moofus02 on Apr 28, 2015 7:47:03 GMT -5
Looking good
Post by Sitticuss on Apr 28, 2015 8:09:47 GMT -5
Looks so sweet...Thanks for pulling it off the trailer and taking a few snapshots.
Post by Lucass2T on Apr 28, 2015 8:20:14 GMT -5
That suspension is sooo sick! I love it! How many mm are the inner tubes?
Post by thatcrazyguy on Apr 28, 2015 8:41:03 GMT -5
That scoot is badass Dave!!
Post by 2TDave on Apr 28, 2015 8:41:29 GMT -5
Looks so sweet...Thanks for pulling it off the trailer and taking a few snapshots. Haha. My sun burn says different.
Post by 2TDave on Apr 28, 2015 8:47:15 GMT -5
That suspension is sooo sick! I love it! How many mm are the inner tubes? 350mm x 30mm. He also has a 28mm iirc tube available that I'm going to use on my retro. I had to get some .5mm shim stock and wrap the tubes for the RX8.
Post by 2TDave on Apr 29, 2015 5:03:04 GMT -5
Anyone of you electrical gurus have a solution to converting the 3 wire fuel sending unit to my 2 wire harness?
Post by 190mech on Apr 29, 2015 5:39:07 GMT -5
If you have a multimeter set to OHMs,check the old unit,empty and full,jot down the numbers..Go to the new unit and do the same test,swapping wires till you get similar results..Im guessing the third wire is a low fuel warning sender..
Post by iwiketuddlz on Apr 29, 2015 10:29:15 GMT -5
Man I love that front end Dave! I Need that!
