Post by niz76 on Nov 9, 2014 17:41:52 GMT -5
I unscrewed the boot from the cable and cut the cable basically in half so it had a nice short distance from coil to plug. Don't know if it helped- or if it'll help u out- just an idea I guess...
Post by 2TDave on Nov 9, 2014 17:54:51 GMT -5
Not a bad idea Niz. The boot is new too but it's the only thing I didn't check. I'll have to do that before I spend the money on another coil or just put on one of the stock ones I have with the NGK boot.
Post by 90GTVert on Nov 10, 2014 7:42:49 GMT -5
The Naraku 2 terminal looks an awful lot like the red hot scrappy coil they offer for the GY6. Since it's no longer grounded to the frame like the 1 pin, you could try tying in a short ground wire to the bracket. I kinda doubt it will help unless there's some sort of wiring or poor grounding issue to the harness.
Post by 2TDave on Nov 10, 2014 9:57:37 GMT -5
I'll check the boot and if the weather clears up take the scoot to look for a spacer for the retro and see if it changes. Otherwise it a waisted $35
Post by 2TDave on Feb 13, 2015 9:17:36 GMT -5
Doing some tuning, test runs and trying out a video app that displays gps info. I hit 69 mph in a tuck just after 5 minutes and still had a couple more mph in the bike but I totally failed to line up a curve approaching a car in my outside lane. I made a temporary phone holder mounted to the bars.
Post by 2TDave on Feb 13, 2015 9:21:32 GMT -5
Sorry the video is sideways. I told you I was computer challenged. lol. The wind was gusty and swirling yesterday. I'll do more when it calms down.
Post by Sitticuss on Feb 13, 2015 9:22:49 GMT -5
what app are you using?
Post by 2TDave on Feb 13, 2015 9:27:43 GMT -5
Vidometer for iPhone.
My Strada.
Feb 13, 2015 10:04:26 GMT -5
via mobile
Post by Lucass2T on Feb 13, 2015 10:04:26 GMT -5
Very nice! Video's are always good! Cool to have gps in a video
Post by 2TDave on Feb 13, 2015 17:51:29 GMT -5
Well crap. My fuel tank is leaking. I used jbweld on a crack I caused rethreading the fuel tap to npt some time ago. Anyone have a Triton clone tank?
Post by niz76 on Feb 13, 2015 21:51:42 GMT -5
Awesome vid! Seems like it hits 60 without even trying haha. I really like that app. Too bad they don't make it for android
Post by 2strokd on Feb 13, 2015 21:54:23 GMT -5
I think i do? I can look in the morning.. Nice vid.. Its hard to get the speed in the vid like that for me. I can tell on your return run your scoot has that 74MPH in it but the way it hit 69. Good work! Be safe!
Post by 2TDave on Feb 14, 2015 15:24:48 GMT -5
Thanks. Let me know if you dig up a tank.
Post by 2TDave on Feb 18, 2015 17:38:30 GMT -5
I'd like to try and repair this tank since I've already tapped it to 1/4 npt. It's got a hair line crack that is away from the tap weld. I used jbweld last time but I'm thinking I opened the crack back up tightening the fitting on it. So I'd have that on and tight before I try to repair the crack. Is there something better for this than jbweld?
Post by niz76 on Feb 18, 2015 18:05:11 GMT -5
Dave- I've been using "Quicksteel" Steel reinforced epoxy putty. Sets in 5 minutes. Full cure in 1 hour. It says it's impervious to chemicals and good to 500 degrees.. blah blah blah. It does list gas tank repair as one of the things to use it for on the back. I have no idea if it's any better than JBweld...
