Post by Lucass2T on Oct 11, 2018 21:38:42 GMT -5
Those are some seriously bad ass numbers for 'just' an old ac motor. Man cant wait to see what it'll do with that parts combo!
Post by PIG on Oct 12, 2018 2:00:19 GMT -5
Those are some seriously bad ass numbers for 'just' an old ac motor. Man cant wait to see what it'll do with that parts combo! You won’t have to wait long. I got the MXS back in tonight. Just gotta let the sealant dry and hopefully if the weather cooperates tomorrow I’ll get it in tune.
Post by aeroxbud on Oct 12, 2018 6:48:45 GMT -5
If it goes anything like the video, hold on tight!😱
Post by PIG on Oct 12, 2018 14:19:39 GMT -5
Yep it’s fast. Definitely faster with this pipe then with that Most Wicked pipe. That Most Wicked pipe is kinda false advertising. Now that I’ve tried the R1400 it’s super obvious it’s not a race pipe as it’s advertised. Still a really nice pipe, but it’s a mid race pipe, a lot like the Polini ForRace4 pipe. So if any of you Prebug guys want a true race pipe, the R1400 and the one Roost makes are really your only options.
Now back to this new combo. It’s now pulling in the 12800-12900 rpm range, up from 12,100 on the S6 Race bore. I had a 142main Jet in it and had to upjet to a 152 and it needs a little more yet. I’ll hit up my local yamaha dealer and get a couple sizes bigger. I also had to drop the roller weight quite a bit. It had 4g rollers in it and now has 3.25’s in it. That’s the lightest weights I’ve ever had in any of scoots. I may end up increasing the rollers after I get some tuning in and compare numbers. Anyways I’m back In love with this scoot, Prebug’s for the win!
Post by PIG on Jun 3, 2019 23:32:47 GMT -5
Ok I’m going to give the old Pre Bug some love and attention. It’s basically just sat since my last post here. A couple days ago I had the motor apart and readjusted the squish to hopefully fix the heat issues I’ve been battling. I have Friday off this week, so I’m gonna bust ass and finally get this thing in tune. I also just placed a decent size order to give the old girl a makeover. New things coming!
Post by aeroxbud on Jun 4, 2019 3:17:41 GMT -5
New shiny parts sounds interesting. It's gone from mild to wild. So what's next. They are such a great scooter, it's a shame to just have it collecting dust.
Post by PIG on Jun 7, 2019 20:15:27 GMT -5
I had some time to do some tuning today and got about 90% dialled in. The carb is really close, but the CVT needs a couple tweaks. I’ll hopefully getter figured tomorrow
Post by PIG on Jun 9, 2019 9:23:44 GMT -5
I’m gonna call the carb and Trans good enough. My parts I ordered should be here either tomorrow or the next day. On a side note I’m really liking these Michelin Reggae Tires. I ride this scooter everywhere. Ditches, gravel roads, woods and the street and tires have handled everything great. If you like to do light off-roading with your scoot give these a go.
Post by PIG on Jun 17, 2019 22:41:12 GMT -5
I’ve been working on giving this scoot a bit of make over and I’m about 90% done. The front body panel is just sitting on there as I still have to wire up the new turn signals, but I just had to see what it will look like. I put a new seat cover on, new rear body work, switched it over to mx style handle bars with new grips and riser. All in all I’m really happy with how it turned out.
Post by aeroxbud on Jun 18, 2019 4:10:07 GMT -5
Looks good. I like it.
Post by Jwhood on Jun 18, 2019 13:40:48 GMT -5
I like those bcd panels bro looks tough bro
Post by PIG on Jun 18, 2019 14:36:04 GMT -5
mattyslimz
Post by mattyslimz on Jun 19, 2019 5:50:27 GMT -5
Ditto Jwhood those panels are pretty slick. Looks good in white too.
Post by PIG on Jun 21, 2019 16:24:27 GMT -5
So I finished doing all the cosmetic stuff and now it won’t run worth a shit. It starts first kick idles perfect but won’t rev out. I’ve cleaned the carb twice, checked the reeds, swapped the coil made multiple jet changes, tried three different plugs and nothing changed. Any ideas on what to check next? Also the headlights don’t work now, but there is power going to them. I wouldn’t think both the bulbs would just burn out at the same time. Edit I just swapped carbs and still the same thing
Post by 190mech on Jun 21, 2019 23:31:07 GMT -5
Strange youve lost lighting AND runs bad,,might pull the flywheel and see if something came loose under there,,
