Post by PIG on Jun 22, 2019 5:23:33 GMT -5
Strange youve lost lighting AND runs bad,,might pull the flywheel and see if something came loose under there,, Did that all looks cool
Post by PIG on Jun 22, 2019 5:25:10 GMT -5
It gotta be something stupid Iām not seeing!!
Post by 'O'Verse on Jun 22, 2019 13:06:04 GMT -5
Are we back to race status exactly like in your sig? It's gotta be something small.... it'll come to you. Might need a black pearl ride and a epiphany š
Post by repherence2 on Jun 22, 2019 19:31:33 GMT -5
could it be the Rectifier?
or the clip coming off the carb needle?
Post by PIG on Jun 22, 2019 21:33:23 GMT -5
could it be the Rectifier? or the clip coming off the carb needle? Iāve been through the carb a bunch of times, pretty sure itās good to go. Iāve checked pretty much everything accept the cylinder and piston. I really donāt want pull it apart but I probably should.
Post by ryan_ott on Jun 22, 2019 22:01:29 GMT -5
Double check that all plugs are snapped together and you didnāt pinch a wire with the body panels.
Post by repherence2 on Jun 23, 2019 1:02:15 GMT -5
could it be the Rectifier? or the clip coming off the carb needle? Iāve been through the carb a bunch of times, pretty sure itās good to go. Iāve checked pretty much everything accept the cylinder and piston. I really donāt want pull it apart but I probably should. yup, that would suck. maybe compression test?
Post by PIG on Jun 23, 2019 22:39:42 GMT -5
I pulled the cylinder and it looks like might have had very minor soft seize. Itās on the intake side which is kinda unusual at least in my experiences. Thatās also where the piston ring pin is. Is it possible I put it together and the ring wasnāt locked in place by the pin? If so would that cause the issues Iām having? Iām at a loss if this isnāt the problem. I didnāt have any sealant to put it back together tonight so itāll have to want for another day.
Post by 190mech on Jun 24, 2019 3:36:36 GMT -5
Doubt if that small scuff would hurt anything,likely a high spot that got honed down during running..
Post by PIG on Jun 24, 2019 7:37:18 GMT -5
Doubt if that small scuff would hurt anything,likely a high spot that got honed down during running.. What the ring was able to move around because it wasnāt located by the piston pin?
Post by tsimi on Jun 25, 2019 19:12:28 GMT -5
The scoot looks fantastic! Well done on the refresh.
You say that the scoot was running fine before you did the fairing and handle bar swap? Did you check all the grounds? My Prebug had a body ground wire inside the stock handle cover which i had to re-attach to the frame at a different place since the nacked handle setup didn't give me any good spot. Maybe you missed a wire when swapping the handle bar?
You still use the stock Iggy right?
Post by PIG on Jul 10, 2019 14:27:18 GMT -5
The scoot looks fantastic! Well done on the refresh. You say that the scoot was running fine before you did the fairing and handle bar swap? Did you check all the grounds? My Prebug had a body ground wire inside the stock handle cover which i had to re-attach to the frame at a different place since the nacked handle setup didn't give me any good spot. Maybe you missed a wire when swapping the handle bar? You still use the stock Iggy right? Just reading this now. Iāll have a look tonight, do you remember what colour the wire was by chance? I got annoyed with the thing and itās sitting in a pile of piece on the floor. Itās probably extra fucked now lol
Post by tsimi on Jul 10, 2019 17:41:13 GMT -5
It was a black wire with a ring connector that connects to the handle bar.
Post by PIG on Jul 19, 2019 16:22:11 GMT -5
Mine doesnāt have that ground, they must of changed things over the years of building them or Iām an idiot witch is probably the problem. Anyways, Iām over this POS. I hope it catches fire.
Post by aeroxbud on Jul 19, 2019 17:34:29 GMT -5
Mine doesnāt have that ground, they must of changed things over the years of building them or Iām an idiot witch is probably the problem. Anyways, Iām over this POS. I hope it catches fire. Put the tools down. Walk away. Tomorrow's another day. š
