Post by AlexF2294 on May 6, 2014 21:39:17 GMT -5
I made a flat gasket but i guwss it didnt like it. Lol
Post by 90GTVert on May 6, 2014 21:58:40 GMT -5
Regular gasket material won't hold up to the exhaust. You need either a material meant for exhaust or you can try high temp copper RTV or both.
Post by AlexF2294 on May 6, 2014 22:05:24 GMT -5
I had some permatex copper on it.
Post by AlexF2294 on May 6, 2014 22:06:55 GMT -5
Such wonderful working conditions i have. Lol.
Post by 2strokd on May 7, 2014 8:34:18 GMT -5
It might work for you with the stock head and higher squish, if the engine is left fairly mild? I would suggest some kind of cylinder head temp gauge so you can see the temp.
The rubber/fiber stuff work pretty good IMO Brent.
Post by AlexF2294 on May 7, 2014 12:27:35 GMT -5
I still need to check my squish. Bit i have some clearance issues with this pipe. It hits my center stand when the shock compresses then gets stuck on it.
Post by AlexF2294 on May 7, 2014 12:43:10 GMT -5
Well i just tried to check my squish. I used some solder that was 3.15mm thick. It didnt even get squished. I could just barely feel the piston hitting it... what do i do now
Post by 2strokd on May 7, 2014 14:47:27 GMT -5
How thick of base gasket total? Maybe you can remove one, or use a thinner one? Other than that it will take some machine work. Do you even have a head with a squish band in it?
Post by 2stroked on May 7, 2014 14:58:32 GMT -5
Same ? I asked him in my thread. Also what type of head gasket are u using. U can maybe eliminate the gasket unless it is the o-ring type. If it is the flat copper type, just give the head and jug a good coat of copper spray, let it get semi set before putting it back together.
Post by AlexF2294 on May 7, 2014 15:06:35 GMT -5
The base gasket is 1.6mm thick and the head gasket is a copper one with a very thin coating of copper rtv on it.
Post by AlexF2294 on May 7, 2014 15:07:18 GMT -5
And you know, i didnt even look to see if i had a squish band on my head when it was off. Stupid me... lol
Post by 2stroked on May 7, 2014 15:44:22 GMT -5
How far below deck does the crown of your piston raise to? Also, tge gasket should crush a little as it is torqued down.
Post by Sitticuss on May 7, 2014 15:51:51 GMT -5
I still need to check my squish. Bit i have some clearance issues with this pipe. It hits my center stand when the shock compresses then gets stuck on it. Had the same issue with my Baccio... I ended up cutting out the center stand.... The bottom of your motor might have the brackets to install a center stand on the actual motor? My work space is only that good when my wife is gone and i can drag the scooter inside. I use that exact same lamp.
Post by AlexF2294 on May 7, 2014 16:18:59 GMT -5
How far below deck does the crown of your piston raise to? Also, tge gasket should crush a little as it is torqued down. I dont know. I put it all back together though and im gonna take it on a test run. I still need to check my squish. Bit i have some clearance issues with this pipe. It hits my center stand when the shock compresses then gets stuck on it. Had the same issue with my Baccio... I ended up cutting out the center stand.... The bottom of your motor might have the brackets to install a center stand on the actual motor? My work space is only that good when my wife is gone and i can drag the scooter inside. I use that exact same lamp. ive had that lamp for years. lol
Post by AlexF2294 on May 7, 2014 16:34:38 GMT -5
I seemed to be running fine at partial throttle and wot but it has ALOT of vibration at idle and if i dont keep the throttle opened a bit when i stop it will drop rpms after a few seconds and die.
