Post by 190mech on May 24, 2014 6:17:47 GMT -5
Here are some pics of my spare big case Yamati 50; Hope this helps..
Post by moofus02 on May 24, 2014 6:54:10 GMT -5
Here are some pics of my spare big case Yamati 50; Hope this helps.. John are those cases the ones that take the 90cc atv parts? If so I've got another code to look for Sent from my SPH-L720 using proboards
Post by 2TDave on May 24, 2014 6:56:59 GMT -5
Thanks. I had heard that the eurostrada was a Yamati but in my case it's the normal 50. I surely would of noticed when I did the 70 kit.
Post by 2TDave on May 24, 2014 7:26:35 GMT -5
I'll check mine when I get home tomorrow. Damn now I'm across the state with new rims that were delivered and this to ponder. Honey pack the car we're going home! Lol
Post by Sitticuss on May 24, 2014 11:16:13 GMT -5
What are the issues with installing a 90cc crank into a 50cc. what exactly do you have to change for the crank? I understand about installing the top end.
Post by nelson on May 24, 2014 14:05:04 GMT -5
The outside diameter is larger than the inside diameter of the cases, there isn't much material there to begin with so a tiny mistake and u have scrap aluminum
Post by 90GTVert on May 24, 2014 14:14:42 GMT -5
Post by Sitticuss on May 24, 2014 15:19:27 GMT -5
Ok I fully understand the concept now thanks. I Don't have the eyes or the steady hands for that anymore. It's something I would be better off paying to have done.
Post by oldgeek on May 26, 2014 21:12:41 GMT -5
Here are some pics of my spare big case Yamati 50; Hope this helps.. My small half case has the same makers mark as the one in your picture, But sadly the numbers don't match. Hope to find one of those some day. I ordered some really cheap priced crank bearings, and a decent burr cutter for aluminum. The bearings are sealed so hopefully they wont get shavings in them. The 1/8" shank by 1/4" round cutter should chew through the aluminum cases with ease, without clogging up too much I hope. I used the great links Brent provided, and checked out my measurements for the crank clearance again. It seems I will have a little less meat left on the cases than I thought, but there should still be enough left to seal up.
Post by oldgeek on Jun 6, 2014 23:38:47 GMT -5
The economy sealed bearings I ordered finally came in. It took them long enough, but they were cheap. I sanded the crank halves where the bearings mount, so I could slip the bearings on and off the crank fairly easily. I did not want them loose to the point where they could fall off. I used a flap wheel mounted in a drill to spin the bearing and cut the outer diameter of the bearing down until it would hand press fit into the case half. Holding the flap wheel at an angle helped the process along, but it still took a good while to get it done. I went to several places today to see if they had a large grinder. I need to get the center area of the crank face flat all the way across it, either by fabricating a 2mm spacer, or grinding 2mm form the semicircle part of the crank half. Nobody I tried had a grinder to do the job quickly. One place said they would do each half for $40.00 apiece sometime next week, I said thanks but no. I guess I will have to find another way to get it done. With the big grinder we had at one place I used to work, I could do the job in 3 min...tops. There is also a picture of the cutter that came in. I need to find out the right speed to use for cutting aluminum, I imagine it will be slow to keep the heat down
Post by oldgeek on Jun 6, 2014 23:50:18 GMT -5
Also If anyone has a junk case half or two I could get cheap, I would really appreciate it. I would like to try this out on a junker, before I try on a good set of cases!
Post by oldgeek on Jun 7, 2014 0:13:54 GMT -5
Post by 190mech on Jun 7, 2014 5:21:03 GMT -5
Its looking good!Like the eccentric idea,mid to high rpm with plenty of lube to keep the cutter clog free.Guess you'll have to take step cuts on the left case half..Still like your router idea too!!
Post by oldgeek on Jun 7, 2014 6:20:47 GMT -5
Its looking good!Like the eccentric idea,mid to high rpm with plenty of lube to keep the cutter clog free.Guess you'll have to take step cuts on the left case half..Still like your router idea too!! Thanks for the hint on cutting speed. The small case half will definitely be the easier one to do, multiple step cuts required for the big half for sure. I figure a flap wheel will take care of the fine finish as needed.
Post by 2strokd on Jun 7, 2014 10:01:14 GMT -5
Good looking set-up there man!
