nightriderrv
Never Give Up- Ride all the time !!!!!
Post by nightriderrv on May 23, 2014 22:51:28 GMT -5
Keep looking you'll them like Brent said check EBay I've found some good deals there.
Post by moofus02 on May 23, 2014 23:03:55 GMT -5
I'm thinking I need to get one of those vapors
Post by dashrite on May 24, 2014 14:20:30 GMT -5
So i changed the back brakes and had to takes the exhaust off. This is what my exhaust port. Is that build up or how the cylinder is? Sent from my SPH-L710 using Tapatalk Attachments:
Post by 90GTVert on May 24, 2014 14:31:42 GMT -5
That's very common on these engines. I think it's a good idea to match it up if you get an aftermarket pipe and/or additional port work, but it's not likely to do anything till then. I tried a before and after on my 49cc project and the results were not worth the effort/gaskets.
Post by dashrite on May 24, 2014 14:32:20 GMT -5
I do see some build up. I was just wondering if the oval shape is normal or its suppised to be a circle shape?
Post by dashrite on May 24, 2014 14:33:41 GMT -5
Well im going to buy an exhaust when i get the bbk. Im also going to get a new carb and intake manifold with reeds.
Post by dashrite on May 24, 2014 14:34:01 GMT -5
Atleast i know it suppised to be there.
Post by 90GTVert on May 24, 2014 14:34:41 GMT -5
Post by dashrite on May 24, 2014 14:37:07 GMT -5
Other then brakes and cluster i dont know what to do with it now lol. I wanna work on it all the time.
Post by 90GTVert on May 24, 2014 14:41:31 GMT -5
You are among friends here. Lots of us have that problem. Years from now we'll probably all be sitting around some sort of scooter rehab clinic.
Post by dashrite on May 24, 2014 14:46:27 GMT -5
Ive been searching all over to find the carbonfiber luggage rack to put on it. Maybe ill buy new tires next.
Post by 90GTVert on May 24, 2014 14:51:44 GMT -5
Vento Triton GT5 had the CF look rack. Strada RX8 and other similar ones had them too. I could have swore I knew where to get one, now can't find it.
Post by dashrite on May 24, 2014 17:11:14 GMT -5
Yeah i found one place listing
It but out of stock
Post by dashrite on May 24, 2014 18:31:23 GMT -5
The inside of the cvt. Couldnt get the belt on cuz i cant get the variator off. I dont have an impact wrench. Searching for one on amazon Sent from my SPH-L710 using Tapatalk
Post by Sitticuss on May 24, 2014 19:27:25 GMT -5
you can use a strap wrench to hold the variator to take it off if you have one.
