Post by 2strokd on May 27, 2014 8:43:49 GMT -5
In the middle of a mild street build and thought ide share. I have some pics but i think my son took the camera, will post later.
Its a 2000 Aprlia SR50 with a LC carbed Minarelli engine. The build will have a 42mm stroke crank with the OD shaved down to fit the small Aprilia cases. We are using a 54mm bore iron cylinder.
i639.photobucket.com/albums/uu112/190mech/rs50-965_zpsfa0c8647.jpg
i639.photobucket.com/albums/uu112/190mech/rs50-966_zps2cad5049.jpg
i639.photobucket.com/albums/uu112/190mech/rs50-967_zpsad31df02.jpg
We opted for a better ProX 85mm connecting rod with a 42mm stroke. At first i planned on using a 45mm stroke crank but the cases proved to be too thin for this. More on that subject....
"Here is an update on Robert's Aprillia RS50 stroker build.We've been spoiled by CPI cases!Robert sent me the cases to bore for the Carlos 45mm crank,I measured them,NO WAY!!These cases are 3mm thinner OD than the CPI stuff(87.1 - 90.1). checked the CPI case OD to the Polaris ATV case,,same OD..Got to looking at alternative cranks,Carlos has a 45mm/10 pin shaft thatll drop in,but we'll have to change the rod for a 12 pin($$)..Then I found out a 50cc crank uses a 16mm big end pin and the 90 stuff uses a 18mm pin,crap!That complicates it more..ProX has a rod kit for the 18 big pin,85mm length,12 pin(03.2002),and they have a 16 big pin,85mm length,12 pin(03.2008)..After a bunch of phone calls we decided to go the cheap route(as always),,Have a Polaris crank ordered($35) and will turn the crank wheels down kinda like Brent's 90 motor and press in a ProX rod kit,that way we'll have a 96.19cc build wedged in the skinny Aprillia cases,,Hope it works!!"
Sometimes even when you "think" you have done your homework and you know an engine something will bight ya!
I have the port matching and trench work about done. Pics and more info to come.
