Post by aeroxbud on Jan 27, 2021 12:04:30 GMT -5
Age I guess. It's hygroscopic, so over time will hold more, and more water. If it's that bad, it probably needs the line changed too.
Post by FrankenMech on Jan 27, 2021 12:08:17 GMT -5
Chinese brake fluid? I have worked on some old cars and trucks and have never seen that.
Post by jbjhillbilly on Jan 27, 2021 16:29:15 GMT -5
That's the worse one I've seen. And I've seen some bad ones. šÆ Totally going swap out the entire system.
Post by milly on Feb 4, 2021 11:40:47 GMT -5
Today I had to chisel off the new cruciform on the cut down and order a new selector after the metal made of cheese knackered the threads and would not undo. Brings to mind the old adage, buy cheap buy twice.
Post by milly on Feb 7, 2021 13:13:12 GMT -5
Packed up all the ET4 stuff to go off with scooter this week when courier comes to collect
Post by aeroxbud on Feb 7, 2021 14:15:34 GMT -5
That looks like nearly another scooter there Milly.
Post by jbjhillbilly on Feb 7, 2021 14:30:58 GMT -5
That looks like nearly another scooter there Milly. Vespa parts tend to breed as quickly as Ruckus bits.
Post by jbjhillbilly on Feb 7, 2021 14:48:33 GMT -5
Finished tearing down a customerās PCX150 that had rear ended a car. Damage all the way back as energy dissipated thru the panels. Pretty much every panel has a crack or tab missing. Wish theyād make body panels out of the same plastic as the floorboards and the like - those stood up well. Iām getting the feeling that they dropped the bike from production because of the labor involved. Honda has got to quit over-engineering every single thing on these bikes just to make things compact. The tail assembly and how it attaches to the rear plastics is a study in nonsense; three different sizes of screwdriver to get at them all (at a bad angle even then). But the worst is these - They are the Devil. I still havenāt found a good trick to get them to pop loose. They donāt even come loose pinched/pushed from the inside. They seem to need to come straight out, but you canāt always pull the entire piece at once. Maybe Honda has a special tool for it. Or maybe servicing major components just means cracking panels and ordering from the Mothership. Oh well. Got an Italian grinder for lunch, so the day should go well. Now to put it back together!
Post by milly on Feb 7, 2021 15:42:16 GMT -5
That looks like nearly another scooter there Milly. Almost bar frame,forks and a few panels š
Post by aeroxbud on Feb 7, 2021 16:04:20 GMT -5
Finished tearing down a customerās PCX150 that had rear ended a car. Damage all the way back as energy dissipated thru the panels. Pretty much every panel has a crack or tab missing. Wish theyād make body panels out of the same plastic as the floorboards and the like - those stood up well. Iām getting the feeling that they dropped the bike from production because of the labor involved. Honda has got to quit over-engineering every single thing on these bikes just to make things compact. The tail assembly and how it attaches to the rear plastics is a study in nonsense; three different sizes of screwdriver to get at them all (at a bad angle even then). But the worst is these - They are the Devil. I still havenāt found a good trick to get them to pop loose. They donāt even come loose pinched/pushed from the inside. They seem to need to come straight out, but you canāt always pull the entire piece at once. Maybe Honda has a special tool for it. Or maybe servicing major components just means cracking panels and ordering from the Mothership. Oh well. Got an Italian grinder for lunch, so the day should go well. Now to put it back together! My CBF250 is the same. There are three screws that hold the side panels on. All three different sizes. Just why Honda?
Post by oldgeek on Feb 11, 2021 19:18:24 GMT -5
It got up to 58 degrees here today, so after lunch I decided to take the blue Kymco for a short ride over to the shop. While I was there, I did some prep work on the naked build. I am hoping to weld the rear seat supports in later this evening after dinner. The ride home around 5:30 was a bit colder. As I got closer to the coast on the way home, I could feel the air turn markedly colder. The blue Kymco noticed it too and gave me a bit more powa!
Post by woodini on Feb 11, 2021 19:38:36 GMT -5
Washed mine.
Post by jbjhillbilly on Feb 21, 2021 22:41:21 GMT -5
New throttle cables, and added a cup holder to the Vino 125. Not sure about the placement of the cup holder (of course this is after I drilled into the plastics).
Post by Deleted on Feb 22, 2021 8:00:09 GMT -5
I never really liked cross-country skiing. But it's a whole new ball game with scooter.
Post by Senna1Rossi on Feb 22, 2021 23:36:28 GMT -5
Wow, look at all that white stuff everywhere
