Post by blackfurypt on Jul 16, 2014 12:13:42 GMT -5
Hi guys I am from portugal and a newbie in scooter tunig. If there is a spell error sorry. I bought a piaggio zipp 2t 50cc AC catalised from 2001 for the kid. He is 1 year away to have the license. The scooter only makes 60km/h at WOT and sometimes makes20Km/h at WOT and i am going to repair it all plastics / security and mecanic and i want to put it to make 110km/h + and paint it black and tune it. Can you guys help me?
Post by blackfurypt on Jul 16, 2014 14:03:38 GMT -5
How do i put pictures in the forum?
Post by 2TDave on Jul 16, 2014 14:11:19 GMT -5
Welcome aboard!
Post by moofus02 on Jul 17, 2014 9:51:52 GMT -5
Welcome
Post by 90GTVert on Jul 17, 2014 11:57:20 GMT -5
I see you already have 1 pic posted, but here's more image posting help if needed : 49ccscoot.proboards.com/post/7984What are the symptoms when it slows to 20KPH? Does it bog, sputter, make any strange noises, etc...? More details may help someone diagnose the issue better.
Post by blackfurypt on Jul 17, 2014 13:03:25 GMT -5
Thanks for the welcome guys.
The 20km/h stall is resolv. Sparkplug burned. Later ill put a photo in here. And auto mixture not suficient. and the oil deposit was leaking. Puted manually in the gas tank and its resolved. Allready making 60km/h but its failing in hi rev when motor is warm in cold works fine. i am thinking its stator or coil problem.
What do you guys think?
Post by blackfurypt on Jul 17, 2014 13:11:13 GMT -5
The scooter is all stock. Going to see if its restricted. In the cdi it is. Thats for sure. In the variator dont know and in mufler its restricted by cat and dont know if it is in the flange.
Does anyone know if there is a transmission longer for this scooter?
Post by 90GTVert on Jul 17, 2014 15:05:50 GMT -5
Possibly the main jet is too small, which would be made a little worse by mixing oil in with the gas. You could try tightening the gap up to see if the high RPM performance improves.
Post by blackfurypt on Jul 18, 2014 11:27:29 GMT -5
Like i dont know how the scooter was treated by the previous owner. And just found out that it has no air filter in the original box. Going to take the box out and put a racing filter. And take the carburator apart and clean it and tune it.
Wat mods do you guys think i should do for beggining Thanks 90gtvert.
Post by 2TDave on Jul 18, 2014 12:33:25 GMT -5
You will need to rejet the carb with a pod or open filter.
Post by blackfurypt on Jul 21, 2014 10:29:00 GMT -5
Going for a open air filter. And jet change in the carb. And open inlet air restritions.
Post by blackfurypt on Jul 22, 2014 21:06:55 GMT -5
Hi guys. Just changed the air filter. To a hiflow 28mm air filter. with max idle mixture the idle is ok Tomorow i'm going to take the carb of to clean it. And change the jets. I think the carbe is a 14 from dellorto. Now i dont know what jets should i put. It bogs if i acell more than a 1/4 trottle.
Also bought today a 3 colors clutch spring kit from topracing and a 5 grs roller kit. Now i am in doubt if i should change variator spring too. Also saw that the original mufler is restricted with a solded fake pipe. And i think that it has vario and clutch and carb restrictions.
Post by 90GTVert on Jul 22, 2014 21:41:52 GMT -5
One thing at a time for the tuning. If you try to do the CVT and carb at the same time it can get difficult to tell what's doing what so dial in the carb first. Not sure what to tell you on jet size, but whatever is in it now I'd go up 10% or more. If the bog is a clean smooth sound it's lean and if it is a sputtering bog it's rich.
Post by blackfurypt on Jul 23, 2014 11:24:29 GMT -5
Of course. First carb tuning. Then gearbox tuning and next cvt tuning.
My carb is a dellorto 17.5 comes stock in scooter 56 & 32 jets and the needle was in top posicion(5) original Just found a 110 that i replaced for the 56 and put the needle in 4 from top to bottom. But it still boggs from 3/4 to WOT think its not enough gas. Because it seems lean.
Do you think i should go up on jet? Because i have just one position that is max needle open.
Post by 90GTVert on Jul 23, 2014 11:41:11 GMT -5
Sure the float height is right and the lines and filter are clear etc...? 56 to 110 is a massive leap in jet size to still act similar. 3/4 - WOT usually would be a main jet issue, but check the rest over first.
