Post by 90GTVert on Sept 8, 2014 18:42:26 GMT -5
Looks alright other than the oil. Don't use a straight 40 weight. You'd want 5W40 - 15W40.
Post by treylaw on Sept 8, 2014 18:44:29 GMT -5
that oil is for the brake in time i thought it would be better
Post by 90GTVert on Sept 8, 2014 18:48:13 GMT -5
If you're using a standard oil normally, it should be fine for break in. If you are using synthetic after break in I'd pick up a quart or two of Shell Rotella T 15W40 for the first couple of changes.
Post by treylaw on Sept 8, 2014 19:06:05 GMT -5
its the same oil ive been buying for it the whole time
Post by treylaw on Sept 8, 2014 19:09:29 GMT -5
Post by niz76 on Sept 8, 2014 19:38:35 GMT -5
Here's the one I've been drooling over at Amazon HERE. Lot's have used this and like it.
Post by 90GTVert on Sept 8, 2014 22:23:04 GMT -5
Post by treylaw on Sept 9, 2014 9:16:23 GMT -5
well i like the look of classic analog needle gauges plus i want the tachometer to be to be its own gauge and the speedometer and odometer to be in one gauges and not drop more than 50 bucks in to them. if you want to see pics of the gauges and the wireing setup friend me on Facebook because i cant just cut and paste them on to here and no i do not like photo bucket and how it clearey sells your pics to 3rd party ppls here is the link to my face book www.facebook.com/trey.law.319 and no this anit some scam
Post by Lucass2T on Sept 9, 2014 12:59:24 GMT -5
Post by treylaw on Sept 9, 2014 14:32:22 GMT -5
oh i forgot to say im open to suggestions on the issue of the tachometer and speedometer/odometer gauge but ownly if there analog gauges
Post by treylaw on Sept 9, 2014 19:42:59 GMT -5
so no sugestions ok fine
Post by 90GTVert on Sept 9, 2014 22:06:06 GMT -5
What you're asking for doesn't leave a lot of options that I know of. If you want analog, separate, and cheap... what you've found is about what I know of. There were some all-in-one clusters with a large analog tach and the rest digital that someone posted a while ago. Examples
Post by treylaw on Sept 10, 2014 10:10:30 GMT -5
well il take any suggestions in the way of analog gauges
Post by 90GTVert on Sept 10, 2014 12:33:29 GMT -5
Koso makes some nice stuff, but the price is way above the others. I have their analog tach with digital CHT built in. Seems to be accurate, but the CHT only goes up to 302F so I think it was more intended for monitoring liquid cooling systems. www.kosonorthamerica.com/koso/scooter_met/
Post by treylaw on Sept 11, 2014 23:34:55 GMT -5
dose any one got any videos on how to do a kick start replacement on my scooter
