Post by birdman on Jan 7, 2015 21:12:40 GMT -5
So now I am happy with my 1990 Yamaha Jog CG50.. The main problem is I cant find a/m gears to get my speeds to the next level, so Im callin this one done at mid 50's and mad wheelies. Now I shall move on to the Elite and build that for 70+mph, wheelis will be optional on the Yeelite. Anyway heres my mid-50 wheelie machine
Mod list- 1990 Yamaha Jog CG50 "old" vertical minarelli
-Malossi Sport 68cc BBK
-Doppler S3R exhaust system
-Motoritec intake manifold w/ 6 reed block
-OKO 24mm flat slide carburetor
-UNI dual-layer foam air filter
-Prodigy overdrive variator
-Custom drilled CVT cover
-STR8 anodized blue CVT cover bolts
-Naraku over sized cooling fan
-Bando high output ignition coil
-NGK ignition wire and cap
-no-rev limit performance CDI
-NGK iridium sparkplug
-Motoritec 10in. rear shock
-101 Octane rear shock spacer (for Zuma)
-Michelin S1's 90/90/10 front and rear
-EBC brake shoes front and rear
-JDM replica integrated taillight for 92 up Jog
-Naraku Sidestand
-Anodized blue Ebay bar-end mirrors
-Pro Taper waffle grips
-Chinese Ebay sound system
-Rustolem white rattle can paintjob.
I was going to do cosmetic mods now like a CW50 Zuma speedometer, paint the rims, source the missing panels, and replace the headlight w/ a blown low beam, and a fancy kickstart lever... But I realized to make this thing a show stopper is more work than it's worth, so it shall stay as a ratty, loud, hooligan, wheelie prone, "party-starting" Jog... I mean did you see my zip-tie "stitches" holding the legshield on?? How about the "lazy-eye" to keep my hi beam from making everyone mad?? So yea... Cosmetics... Forget it, this wheelie bike is prone to continuous dropping anyway #stuntlife
Thanks for looking at my first ever scooter project, on to scoot 2 The Elite AF16 build..
-Naraku Sidestand
