Post by ryan_ott on Jun 27, 2016 20:27:51 GMT -5
I'm not sure the OD of that one is? I had a 115mm Minarelli on here before, just needed some shimming. I think this one is 119mm.
Post by spaz12 on Jun 27, 2016 20:30:45 GMT -5
I might be thinking of niz76?
Post by 190mech on Jun 27, 2016 20:39:10 GMT -5
Post by spaz12 on Jun 27, 2016 20:45:13 GMT -5
Damn, I that's cool. I have a few of those pulleys. I'll have to try one and see if they're one's that will fit. Thanks 190 for looking that up!
Post by ryan_ott on Jun 27, 2016 20:52:09 GMT -5
An aprilla sr50 ditech rear pulley can be made to fit on minarelli by changing the needle bearing. Let go check the diameter.
Post by 190mech on Jun 27, 2016 20:58:19 GMT -5
Darn!Thats a biggun,,Ive got one in the garage,thought we'd have to grind the cases to daylight for fitment!Quit thinking about it after that,,,
Edit; SR50 TD I had in the garage is,130mm OD ,inner bearing ID is 22ish MM,Mina is 17MM
Post by ryan_ott on Jun 27, 2016 21:01:10 GMT -5
It's just under 130mm it's off a '03. It fits the longcase clones.
Post by ryan_ott on Jul 2, 2016 20:31:11 GMT -5
Post by oldgeek on Jul 2, 2016 21:07:44 GMT -5
Nice upgrade. Hows that Phongeer drive face (in the background of the picture) been working for you?
Post by ryan_ott on Jul 2, 2016 21:17:01 GMT -5
It's been great! Early on I thought I was going to have issues with wear with the estart. Not that I use it often. I was checking it out and it's fine.
Post by niz76 on Jul 2, 2016 22:53:10 GMT -5
Post by ryan_ott on Jul 3, 2016 16:03:11 GMT -5
Post by Jwhood on Jul 3, 2016 16:37:06 GMT -5
Just hooked up my stage 6 today real easy instruction!!
Post by ryan_ott on Jul 3, 2016 19:48:44 GMT -5
I forgot to mention there is a warning light that can be used for your low oil light if your still using your oil pump. Pretty neat little gauge.
Post by ryan_ott on Sept 2, 2016 19:56:40 GMT -5
No updates since July... Oh because all has been great. So I decided to try screwing it up and I'm determined to get my Polini PWK 24 to work on this bike. I've never liked the temps I've seen with it in the past so I tried again today. Went pretty high on the pilot and low on the main as Brandon mentioned and what do you know. It's pretty damn snappy. Rpms are up 500 during acceleration. Temps are ok. 320-330 cruise, 350 full throttle. A little needle work and it should be good. Temps are a bit higher but it's a lot more responsive. Lifted the wheel coming out of a corner. Checked my pants they are still clean.
