Speedy
Sept 17, 2011 18:33:14 GMT -5
Post by 90GTVert on Sept 17, 2011 18:33:14 GMT -5
Looks like Speedy means business. Interesting handle bar setup. Beefy support. I think you've been doing your homework on 2 wheeled dragsters. Keep up the good work, and keep posting pics. I love this kind of project.
Speedy
Sept 17, 2011 20:28:10 GMT -5
Post by Reign on Sept 17, 2011 20:28:10 GMT -5
Got her to fire up today too :thumb: Sounded pretty beefy without an exhaust on it. Before I even had any gas hooked up to it, I sprayed ether in the carb to see if she'd fire. 3 kicks and it fired up for about 2 seconds and died. I didn't think that was too bad for a first try!
Speedy
Sept 18, 2011 9:27:30 GMT -5
Post by Reign on Sept 18, 2011 9:27:30 GMT -5
I notice there's some exhaust gaskets in the template section. Doesn't an exhaust gasket have a crush type material (corrugated aluminum?) inside of it? Or can I just use regular gasket material to make my own? I really don't want to spend $13 on 2 gaskets if I can use material I already have.
Speedy
Sept 18, 2011 13:24:38 GMT -5
Post by 2strokd on Sept 18, 2011 13:24:38 GMT -5
You should be fine with any high temp gasket material. Looks cool! Keep it up man
Speedy
Sept 18, 2011 13:26:50 GMT -5
Post by 90GTVert on Sept 18, 2011 13:26:50 GMT -5
The only time I use gaskets anymore is for the stock style setup with an o-ring. Otherwise I just use copper rtv. As long as both surfaces are clean and everything lines up OK, it works fine.
byte
Speedy
Sept 18, 2011 23:48:59 GMT -5
Post by byte on Sept 18, 2011 23:48:59 GMT -5
If you have lots of spare time and not feeling lazy, you can use old/used aluminum soda cans. Wrap those ordinary gaskets with some layers.
Speedy
Sept 23, 2011 11:53:18 GMT -5
Post by Reign on Sept 23, 2011 11:53:18 GMT -5
Speedy
Sept 23, 2011 11:55:57 GMT -5
Post by 90GTVert on Sept 23, 2011 11:55:57 GMT -5
Thanks for the photos. Nice stand. I notice you even gutted the hand controls. Good stuff!
Speedy
Sept 23, 2011 11:58:14 GMT -5
Post by Reign on Sept 23, 2011 11:58:14 GMT -5
Yeah. It cleaned up the wires and stuff that were hanging around up there. I left the turn signal switch in place. Figured I could maybe use it for my nitrous switch. :twisted:
Speedy
Sept 23, 2011 13:26:30 GMT -5
Post by 90GTVert on Sept 23, 2011 13:26:30 GMT -5
Kinda surprised you didn't go with the starter button for that since it's a momentary switch at thumb's reach. Cool either way.
Speedy
Sept 23, 2011 13:45:11 GMT -5
Post by Reign on Sept 23, 2011 13:45:11 GMT -5
Mail just came, and I got a present in a box I didn't feel like spending a whole day designing another tank adapter and in-line petcock. Found this little gem online. 14mm x 1.00 pitch thread, so it bolts right into the tank without any modifications. Built in tank filter, and built in manual petcock. Pretty cool if you ask me!
Speedy
Sept 23, 2011 13:51:27 GMT -5
Post by 2strokd on Sept 23, 2011 13:51:27 GMT -5
looks great:) !! Hows it running? Noticed a Yasuni pipe, any good tests yet? i like bars as well. low and out front like drag bars should be. Since you mentioned it, what kinda of nitrous kit will you be running? Mind filling me in, or do i gotta wait till the 9th?
Speedy
Sept 23, 2011 14:00:10 GMT -5
Post by Reign on Sept 23, 2011 14:00:10 GMT -5
You'll get to see it at the track It's running really rich right now, so I havent been able to test it too much. I was waiting for that petcock to come so I can get to tuning with Methanol. After switching over, it shouldnt be rich at all. It may even be a bit lean. But the jet set I bought for my 22mm carb also works on the carb I have on there. I got lucky there :thumb:
Speedy
Sept 23, 2011 14:54:59 GMT -5
Post by 2strokd on Sept 23, 2011 14:54:59 GMT -5
I just am hoping its at least some kinda wet kit. Your very limited with a dry shot of nitrous. I dont think a 2T would like that much.?. Best of luck with your tune and set-up ! Whatever it is lol?
Speedy
Sept 23, 2011 20:03:16 GMT -5
Post by 190mech on Sept 23, 2011 20:03:16 GMT -5
You could fab a spray bar from brass tubing like this; And control the fuel feed with a model airplane engine carb needle like this;
