Post by rehabkymco on May 14, 2020 16:54:11 GMT -5
Back home and happy to report that I only had 3 minor part failures. The battery in the temp gauge died, the plug boot decided to quit holding the plug, and the tach died. I can get a battery no prob, done stole the NGK resistor boot from my kymco. The only true death then is the tach and that ain't bad.
Post by rehabkymco on May 17, 2020 7:27:51 GMT -5
Post by rehabkymco on May 17, 2020 11:26:19 GMT -5
Switched up to the white mid tension clutch springs. That has slightly helped the acceleration from launch. Which was expected. Without a tach I'm not sure the exact but it still below where the pipe comes in at. Which is around 7500.
Post by rehabkymco on May 17, 2020 12:59:40 GMT -5
New personal best top speed, 330 and 0 to 40. Personal best 1/8 mile is 14.3. With it only being 67 today and 85 the last couple of days has confirmed that 112 main jet is great for cooler weather but a tad rich for 85F and higher, for power anyway.
Post by aeroxbud on May 17, 2020 17:27:41 GMT -5
So close to 60mph! 👍 Just wondering, does your rear shock bottom out at all? It's quite long, but the coils are very close together.
Post by rehabkymco on May 17, 2020 17:53:55 GMT -5
So close to 60mph! 👍 Just wondering, does your rear shock bottom out at all? It's quite long, but the coils are very close together. Yea she's a spine breaker. It's quite soft. Which is,in my thoughts, the reason the front wheel won't come up. But then again the front suspension is soft too.
Post by Zino on May 18, 2020 7:39:11 GMT -5
Nice pics and speed . That is a nice app with aklot of info which one is it. You wont need to move much for Jets in snowmobiles we had to set them fora 40 degree temp difference . Are General rule was 5% change for anything out side that range . So we set them to run right at 10 below zero to 30 above . The focus was to make sure it as safest when cold and it would be a tad rich when things warmed up.
I just swapped the back shocks on the vino's ,What a ride difference .
Post by rehabkymco on May 18, 2020 12:03:10 GMT -5
Nice pics and speed . That is a nice app with aklot of info which one is it. You wont need to move much for Jets in snowmobiles we had to set them fora 40 degree temp difference . Are General rule was 5% change for anything out side that range . So we set them to run right at 10 below zero to 30 above . The focus was to make sure it as safest when cold and it would be a tad rich when things warmed up. I just swapped the back shocks on the vino's ,What a ride difference . The app is called Car Performance by unNull. It's really good. Acceleration and braking. A speedo
Post by rehabkymco on May 21, 2020 15:25:58 GMT -5
Well 200 miles roughly and done blew up again. This scoot is now quite a bit more costly then the drug addiction I had, and use building scoots to over come.
I swear I want to light this thing on fire and walk away
Post by aeroxbud on May 21, 2020 15:30:48 GMT -5
On no. What do you think went wrong?
Post by rehabkymco on May 21, 2020 16:37:45 GMT -5
On no. What do you think went wrong? [ma br] Not real sure yet. Although it did all of a sudden this morning it started sounding lean. But with no tools at hand( something I will be remeding quickly) I couldn't pull the plug to check. Got it on the trailer now. Back to square 1
Post by Zino on May 21, 2020 17:43:26 GMT -5
WTf That sucks it was just starting to get broke in .
Post by rehabkymco on May 21, 2020 18:07:07 GMT -5
That's the plug. Looks ok to me but obviously I'm not well versed with 2T.
Post by rehabkymco on May 21, 2020 18:09:34 GMT -5
WTf That sucks it was just starting to get broke in . This is my thoughts exactly. WTF oh and FML
Post by Zino on May 21, 2020 18:40:45 GMT -5
Color looks ok Did it seize ? Or make weird noises ? What were your temp rang on your gauges ? Did you lose a clip or something like that ?
