Post by hippo008 on Aug 3, 2021 19:37:36 GMT -5
Short update. I still have hanging idles when I come down from 7000rpm and cylinder head temps over 250. I'm seriously confused.
Post by hippo008 on Aug 6, 2021 16:25:38 GMT -5
So I tried every single jet I own. I tried a compression test, another leak down test, new gas, different radiator lines, every pilot jet from 30 to 48 and every main jet from 100 to 115. Nothing brings the Temp down low to the 150° area where I should be.
The only thing I can think of is that my radiator is shit in terms of cooling capacity.
Post by Zino on Aug 21, 2021 20:19:05 GMT -5
What belt size are you running . I sent you that the larger polini belt and you were running a dayco belt with your malossi variator . Whichever one works best for travel front and back compared to the stock belt .
I am putting another parts order together with a malossi variator so I was looking to upsize the belt from my current stock belt .
Post by hippo008 on Aug 21, 2021 20:55:45 GMT -5
What belt size are you running . I sent you that the larger polini belt and you were running a dayco belt with your malossi variator . Whichever one works best for travel front and back compared to the stock belt . I am putting another parts order together with a malossi variator so I was looking to upsize the belt from my current stock belt . I am running the Dayco belt you sent me. No problems with it! I think it's a necessary upgrade
Post by Zino on Aug 22, 2021 7:12:34 GMT -5
Post by czechjo on Sept 2, 2021 7:34:50 GMT -5
Hi Hippo008 i started to do a similar build in 2018. I put a 14/41 polini secondary gear on thinking this would allow me to keep the stock crank without it being over worked. What do you think? . I have the 70cc malossi kit and yasuni r exhaust. Also which carburetor for you end up going with?
Post by hippo008 on Sept 2, 2021 12:17:53 GMT -5
Hi Hippo008 i started to do a similar build in 2018. I put a 14/41 polini secondary gear on thinking this would allow me to keep the stock crank without it being over worked. What do you think? . I have the 70cc malossi kit and yasuni r exhaust. Also which carburetor for you end up going with? With a Yasuni R and Malossi Sport cylinder i bet you could run a stock crank. You should probably use a 17.5mm carb.
Post by czechjo on Sept 2, 2021 18:24:50 GMT -5
Ok Hippo008 Do you have a complete build list on here?
Post by hippo008 on Sept 2, 2021 22:14:15 GMT -5
check the build thread
