rockyp
Post by rockyp on Aug 4, 2020 19:51:55 GMT -5
What would I be looking for in exact plug size or model #. NGK Br9hs ?
Post by Zino on Aug 4, 2020 20:29:37 GMT -5
correct if you are running the ngkbr8hs then ngk br9hs is a notch cooler .
Post by Zino on Aug 7, 2020 7:41:39 GMT -5
Looks sharp .
Post by aeroxbud on Aug 7, 2020 9:49:03 GMT -5
Nice job. Paint has come out well. I would get some ally foot plates so you don't ruin the paint where your feet sit.
rockyp
Post by rockyp on Aug 7, 2020 15:22:38 GMT -5
Nice job. Paint has come out well. I would get some ally foot plates so you don't ruin the paint where your feet sit. Can you post a link to those. Scooter searches here in Canada don't pull anything up for ally or even just scooter foot plates in general. Cheers
Post by aeroxbud on Aug 7, 2020 17:41:40 GMT -5
rockyp
Post by rockyp on Aug 7, 2020 23:11:36 GMT -5
rockyp
Post by rockyp on Aug 7, 2020 23:13:44 GMT -5
It didn't look finished to me so I went ahead and painted the shock towers and brake caliper also. I really want to get a bit of white on my seat. Anyone had any luck with a white seat?
rockyp
Post by rockyp on Aug 7, 2020 23:19:34 GMT -5
Post by aeroxbud on Aug 8, 2020 4:41:16 GMT -5
That was just an example of what I was talking about. It wouldn't be hard to make something similar out of checker plate.
Post by Zino on Aug 13, 2020 17:58:51 GMT -5
ON the bug eye zuma we have a little tube in the bottom corner that catches the extra oil that Back flows into the carb . I have not got my hands on a prebug in awhile so I remember the airbox is different .
rockyp
Post by rockyp on Sept 16, 2020 0:10:50 GMT -5
Update.... she's been a solid reliable haven't touched a thing unit all season. I been riding it hard and I've noticed the front brake lever you have to pump few times to get it loaded up and no fluid loss. Honestly they are kind of lacking with the power upgrades and with how large I am, I would really like to to upgrade them. Can you get a larger rotor and double piston setup for these? Also with the pumping action needed thats a master cylinder issue correct? I1
rockyp
Post by rockyp on Sept 16, 2020 0:12:24 GMT -5
is there a master cylinder rebuild seaL kit available?
