Post by FrankenMech on Oct 21, 2020 18:54:30 GMT -5
You are finding out why an Engineer spends so much of his/her time with make/buy decisions and just sourcing parts. Just when you think you have found the right part it has gone out of production....... AAAARRRRGGGGHHHHHHHHH!
Post by jloi on Oct 21, 2020 20:40:10 GMT -5
yeah, I reckon so . so the copper turned out smaller than I liked . so I made another round from the stainless. gonna do this one different . to do what I want I need to get a 17mm steel bit . largest I have is 1/2" .... mo money
Post by FrankenMech on Oct 21, 2020 22:10:47 GMT -5
Post by jloi on Oct 22, 2020 2:01:15 GMT -5
that's a good idea 2 . I looked at some like that - different name ; couldn't find right size - that 1 might be ok .
what's in a name ? fuckin everything these days .
Post by jloi on Oct 22, 2020 19:07:37 GMT -5
the stainless round turned out ok. finally decided on a stepless bit - from HF - $8.99 did a stainless test piece 1st - thank the search and drill bit gods - it works great - got the hole I wanted , sized up, so it tightens up - broke out the mini lathe - used a file and some emory cloth glued it on with the clear weld now I just need to find a rubber buton or whatever to fit into the 17.4 mm hole. I'm thinking a 16-17 mm id will work . I see these -says there plastic tho -
I'd druther rubber will call them tomorrow . I'm either the worst searcher or google, ama. , ebay totally suck .
Post by jloi on Oct 22, 2020 19:14:56 GMT -5
Post by aeroxbud on Oct 23, 2020 6:36:14 GMT -5
Come out really well. Great work.
Post by jloi on Oct 23, 2020 9:56:17 GMT -5
hey, thanks . now all I gotta do is find the right rubber piece . I might have to do some surgery on it.
Post by jloi on Oct 23, 2020 11:05:40 GMT -5
Man, wow. look what I found- free of charge - they'll send a sample - www.caplugs.com/ergonomic-button-plugs-bpfe ordered 2 diff sizes close together - I love the web soo much . Oh , wait , no I don't ; but sometimes it works ok. actually I shouldn't complain too much given everything I accomplish over the web .
Post by jloi on Nov 1, 2020 12:55:55 GMT -5
the sample rubber plugs came . real beauties , works perfect. but dang it , the black rubs off on my hands , real dusty and a bit of red rust is showing up ; even if I oil them or lube them . I'll try some lithium grease . should hold it off for a while
Post by FrankenMech on Nov 1, 2020 13:14:41 GMT -5
Spray some oil inside the vise.
Post by jloi on Nov 1, 2020 13:18:04 GMT -5
I got some spray lithium grease ? or some spray lube ?
Post by FrankenMech on Nov 1, 2020 14:18:08 GMT -5
Spray lube then some lithium.
Post by geoffh on Nov 1, 2020 16:30:08 GMT -5
All my tools have aged just like me :)any marks chips rust etc just add value and interest,it,s patina and it,s not available online . Geoff
Post by jloi on Nov 1, 2020 21:16:09 GMT -5
yessss , you're right .
