Post by x7rocks on Apr 27, 2022 11:57:58 GMT -5
Thank you so much man. This is why this community is the best 🤩
Post by x7rocks on Apr 27, 2022 11:59:40 GMT -5
This sounds fast and fun You are really pushing the envelope . I feel so boring I just build to 70 cc with aftermarket parts . Hey now they are still really fun to build and definitely haul ! 70s will still be the go to for minarellis as they're just so fun to build 😁
Post by x7rocks on Apr 28, 2022 14:56:07 GMT -5
Okay so little update on the exhaust measurements. They're confirmed to be jolly moto exhaust measurements. I think if any exhaust were to be used, this would probably be the best to go with.
Crank and adapter have been ordered and will be ready by the 5th for shipment.
Post by x7rocks on May 3, 2022 16:06:37 GMT -5
Post by filipebaptista on May 9, 2022 15:51:18 GMT -5
Wanted aerox wheels. So i had a hub made from taiwan. And snagged the last charmo liquid cooled cylinder taida had in stock Hello, can you please tell me were i can buy this hub? I can´t find any seller in Europe with this.
Post by ghostaroni on May 10, 2022 3:59:24 GMT -5
Small update. Mixed the 3 6.8 rollers and 3 7.0 rollers. An that's the perfect number. Right into the powerband to the point you feel the front end just feel light when accelerating. Definitely a game changer. But may need ideas for a stronger waterpump. But will get a video soon. Got a new job at Wheels lab inc where I work on those little electric rental scooters. But this does mean a bit more funding for cool stuff Next mod. Malossi 128mm rear pulley. Hopefully i don't need to cut too much from the cases. 😎 Whats the water pump look like? Maybe its in the realm of my 3 axis.
Post by x7rocks on May 11, 2022 12:48:02 GMT -5
Small update. Mixed the 3 6.8 rollers and 3 7.0 rollers. An that's the perfect number. Right into the powerband to the point you feel the front end just feel light when accelerating. Definitely a game changer. But may need ideas for a stronger waterpump. But will get a video soon. Got a new job at Wheels lab inc where I work on those little electric rental scooters. But this does mean a bit more funding for cool stuff Next mod. Malossi 128mm rear pulley. Hopefully i don't need to cut too much from the cases. 😎 Whats the water pump look like? Maybe its in the realm of my 3 axis. Hello, it's the same Bosch pump stage 6 uses. This is the listing I bought it from. Bosch Automotive 0392023004 Electric Water Pump, 1 Pack www.amazon.com/dp/B00BHKW92Y/ref=cm_sw_r_apan_i_CP1ZVX0C4ESN2H6CE19Q?_encoding=UTF8&psc=1Sorry for slow updates gentlemen. Just waiting on the crank and adapter to arrive.
Post by ghostaroni on May 11, 2022 22:19:06 GMT -5
Oh i thought it was a flywheel pump ): Can't really help on the electronics side. Unless I made an entire pump assembly; Cannot help you there. Sorry friend.
Post by x7rocks on Jun 4, 2022 17:36:34 GMT -5
Gentlemen, I wish i can post here with news of parts arriving. However that's not the case. But. There is some positive news. I sent the cylinder to Columbia for berrugo to understand the different exhaust port angle. Once I receive the crank and cylinder adapter. I will send him measurements to make the mounts for the exhaust to be held. He decided the jolly moto design is simple enough to replicate. So that's a go. But I did pick up something in the meantime to keep me entertained. youtu.be/pzikPCQgXp4
Post by x7rocks on Jun 9, 2022 8:00:26 GMT -5
Gentlemen,i finally received packaging info.
ttrmc makes good bws125 parts. But are slooooooooow when it comes to having their bws100 parts made and shipped. Hopefully it arrives quickly.
As for today, I will be working on the malaguti f12. I will make a separate thread for it.
Post by x7rocks on Jun 21, 2022 7:36:06 GMT -5
Imagine my excitement to see this. Early in the morning. My reaction was close to this
Post by x7rocks on Jun 21, 2022 7:47:04 GMT -5
Post by x7rocks on Jun 30, 2022 8:37:35 GMT -5
I have found a cylinder head! Was trying to find a good deal on a cylinder head. Kept finding used ones for 280 dollars or so but found this one for. 55 bucks. A score is a score 😁 next is gaskets and a piston which will be easier to get a hold off.
Post by benelli49x on Jul 5, 2022 18:41:53 GMT -5
Post by benelli49x on Jul 5, 2022 18:42:35 GMT -5
Working in timing. Seems to always hang around 20 degrees at idle and 39 when i begin to rev. Gonna let it cool down and retard timing by around 5 degrees and try my luck. Will post a video for you guys before the end of the day.
