Post by kevin55950 on Jan 28, 2013 10:16:44 GMT -5
scootertuning.ca/en/lighting/40010-tail-light-str8-black-line-led-universal-15x85cm.htmlI ordered this one for my atv, it's bright and has the blinkers. Wiring is odd, you have to figure it by yourself (I don't know why they don't give a wiring diagram with those, I know the green wire is ground but you see the rest by looking inside the lens, where the wires are coming from) I've made my bracket with a teflon plate, it's flexible and very hard, it will not crack soon, and it absorbs vibration.
Post by 90GTVert on Jan 28, 2013 11:04:32 GMT -5
Easiest way, for me at least, to figure out the wires to those real quick is with a battery. Most are a single ground, so hook that up and then touch the other wires to positive and see what lights up and write it down. Takes about a minute to figure out what's what and note it.
Post by 89CamminGT on Jan 28, 2013 14:57:28 GMT -5
Thanks a lot guys. I will be looking into making a bracket I guess.... dont really have a choice at this point huh lol
Post by 89CamminGT on Jan 31, 2013 16:39:13 GMT -5
Post by 89CamminGT on Jan 31, 2013 16:43:43 GMT -5
I have decided to cut up the exhaust and go another route with it today. Mainly because it was way too loud to ride. Everybody looked when I came screaming down the road wide open. So now I made a flange for a motorcycle muffler I had laying around. The muffler is in VERY rough shape, but it sounds good so I will use it anyways. Or maybe my $400 D&D muffler. Still not sure yet.
Post by 89CamminGT on Feb 2, 2013 17:07:08 GMT -5
Post by 89CamminGT on Feb 4, 2013 1:48:27 GMT -5
Post by 90GTVert on Feb 4, 2013 11:02:45 GMT -5
Sounds good. So there's a working bracket on this one?
Post by 89CamminGT on Feb 4, 2013 20:15:04 GMT -5
A working bracket? Please elaborate lol I dont understand
Post by 90GTVert on Feb 4, 2013 22:20:55 GMT -5
I just meant, you have it supported somehow other than the header connection?
Post by 89CamminGT on Feb 4, 2013 22:29:42 GMT -5
Ohh... yes of course. I will get pics of the bracket soon. Its on but not finished (paint). And thanks to my buddy 90GTVert I have successfully modified my CVT to achieve a higher top speed. I havent hit the streets with it yet, but it has to have more top end now. What I did was Modify the faces of the variator assembly as well as extend the area that the rollers well....roll to. My max speed was 60mph before I done any of this. I will report my next speed readings next time that I go for ride and have my gps speed recorder on. Here are some pics Before After
Post by 89CamminGT on Feb 6, 2013 3:10:03 GMT -5
A pic of my bracket for my friend Brent
Post by 90GTVert on Feb 6, 2013 8:17:41 GMT -5
I thought that may have been what I was looking at in another pic, but wasn't sure.
Post by 89CamminGT on Feb 26, 2013 15:01:13 GMT -5
Post by 89CamminGT on Mar 2, 2013 19:47:10 GMT -5
Updated Pics.. Lowered the front a bit more and finally got around to welding the seat frame in. Still not finished yet tho...
