Post by 90GTVert on Mar 8, 2014 15:57:56 GMT -5
Glad we can be of some assistance. I'll get that stuff out early next week.
Post by 2stroked on Mar 8, 2014 16:11:45 GMT -5
Thank you all so much. As parts, donations are mailed out, could the senders please let me know the day that the pieces are mailed. I have a demented neighbor and I have had mail/packages " appear " at her house, and it took me over a week each time to retrieve my belongings. So now when my wife and I are expecting anything, my wife babysits the mail box around time for the mailman. That way I know I get my mail on time. Tthanks again.
Post by 90GTVert on Mar 8, 2014 16:24:59 GMT -5
I just printed the label via UPS and it should send you a tracking number so you'll know exactly what's up. It'll be dropped off Monday, and says delivery Wednesday for the estimate.
Post by moofus02 on Mar 8, 2014 17:11:29 GMT -5
Man I'm sorry for the loss but glad things are looking up
Post by 2stroked on Mar 8, 2014 17:29:34 GMT -5
Thank you 90,I just got the email.
Post by tomcatsdb on Mar 8, 2014 20:11:46 GMT -5
Glad things are looking good for the build getting finished out.
Post by 190mech on Mar 8, 2014 20:13:54 GMT -5
Dang Chris!If this keeps going on,you'll have 1 bad scoot!!
Post by 2stroked on Mar 8, 2014 20:25:16 GMT -5
I will just be happy to ride my scoot. But yes the members of this forum are great and many have helped/offered to help. As stated before, this scoot will proudly wear the 49ccscoot.com logo, because it would probably never get finished if it wasnt for you all. Again, THANK YOU ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Post by nelson on Mar 8, 2014 20:43:22 GMT -5
I have a 70 cc bbk i am going to send you so plan accordingly. I will have it out this week. Message me your info I will send you a tracking# when it ships usmcdoc, they are stock size, but I am not sure about the weight. I am unable to refuse your help atm. I thank you sir. When I had it apart cleaning everything, I inspected the rollers, and saw only flat spots, and no weight markings, and I do not have a scale. So I am not sure what size. I weigh around 185 and it is a stock top end, and the terrain around here is rather hilly, if any of that helps. The Chippewa were right. Ok..so it is a stock 50cc top end? I would go with 5 gram..they will give better take off and not rob your top end. I put a set in a for a guy that weighs 205lbs and it was MUCH better than the standard 6-7 gram ones...which gave him a slow take off and speed loss uphill. If the Rollers are worn..is the Variator worn too?.. If so I got a barely used KOSO one of those..it is 21mm and some scoots use 18mm as ya know. Just let me know what size shaft yours is if it is worn..and message me your addy so I can ship the stuff off.
Post by nelson on Mar 8, 2014 22:50:58 GMT -5
Ha, just so happens it is a polini bbk! I will hone the cylinder bfore sending it. You may need a new head gasket but I think the rings are ok. The engine had good compression before I took it down. This baby should have you scooting down the road!
Post by nelson on Mar 8, 2014 22:53:27 GMT -5
The scoot is from Hawaii so there is some rust on the outside I'm sure u can get a wire brush if you are worried about loooks.
IMG]http://i58.tinypic.com/9rt3xv.jpg[/IMG]
Post by nelson on Mar 8, 2014 22:54:17 GMT -5
Post by nelson on Mar 8, 2014 22:57:27 GMT -5
Let me know if you think you can use this? I tried to get it cleaned up a bit but the wife wasnt too happy with my hours in the garage Plus trying to get my own engine together. Thats great you will have a good running bike all for $300 !
Post by usmcdoc on Mar 8, 2014 23:10:56 GMT -5
Wow! The markings on the head and the longer cooling fins on the cylinder..it looks like it is a Polini Corsa.. If so that is a BIG dollar kit..yikes..
Post by nelson on Mar 9, 2014 0:43:17 GMT -5
Yea, I was trying to consider if I should send hI'm the newer kit I got from you and he could just put in without much thought. If I send hI'm the polini it will be wasted with a stock pipe would the polini run better on my bike with the zxr pipe or just keep the cylinder I have and ship the polini? Any help here?
